Trav_lr
- Aug 13, 2022
- Birch Bay, Wa
- Fleetwood
- Expedition 38L
- JK Rubicon, KL Trailhawk
No, no, no, the odometer in the 1997 to 2006 TJ absolutely does NOT accrue mileage, nor does the speedometer work when transfer case is in neutral for towing. The last Wrangler that did accrue mileage was the YJ up to model year 1995. In those, the speedometer/odometer cable had to be manually removed from the transmission! On the TJ, the steering wheel lock spring can easily be removed in about 5 minutes with a phillips screwdriver, details are all over the interweb Jeep forums.The only thing I'm still not getting from this discussion is if mileage actually accrues while towing. I see that in some instances the speedo operates, but mileage? I'm not always the quickest on uptake, so please excuse me if this has already been explained.I did note that when I put the ignition switch on our TJ to the first click forward, no accessories turn on and the odometer display does not illuminate
