BGMAC
RVF Expert
- Jan 28, 2020
- Cypress Inn, TN
- Forest River
- Georgetown XL M-369DS
- 37ft
- F550
- Titan V10
- 2020 Polaris Slingshot
Been flat towing a 2016 grand Cherokee 4 wheel drive automatic transmission for about 4 years with no issues at all. Speedometer does not advance while towing. Hooking up to tow is easy. Just disengage the transfer case by pushing in a button with a ball point pen. I use a brake buddy and a blue ox tow bar.Cars are not like the bikes we rode as kids with the speedo connected to the front tire. On the older mechanical ones the speedo gear is in the transmission. Since the driveline is in neutral it will not register miles. Probably on the 2003, its ecm driven. Does not matter if its a digital or mechanical speedo, it will not register miles. I detest liars, you dodged a bullet
YeppBeen flat towing a 2016 grand Cherokee 4 wheel drive automatic transmission for about 4 years with no issues at all. Speedometer does not advance while towing. Hooking up to tow is easy. Just disengage the transfer case by pushing in a button with a ball point pen. I use a brake buddy and a blue ox tow bar.
I can't remember which model year but Chrysler eventually removed the steering wheel lock on the TJ.This might explain why the steering wheel in the 2000 TJ I just bought does not lock at ALL?
The steering wheel lock on the Wrangler was removed about 1/2 way through the 2008 model year...I can't remember which model year but Chrysler eventually removed the steering wheel lock on the TJ.
