rv4travlin
- Oct 12, 2020
- Henrico VA
- forest river
- sunseeker
- 29'9"
- Ford E450
- V10 Gas
- Bufo quercicus
If it was, it never said so on computer, ever no present codes, no stored codes.. nothing at all.. starts and runs great everytime , never got hot ..just a loss off power whenever I kick into passing gear.. engine was actually pinging real bad was scary was worried about permanent damageSounds like it in limp home mode
Not the sensor you were correctKeep looking! I think it's not that sensor! Why? Because throttle sensors typically have a dead spot, and when past that location resume proper operations!
Thanks I will check it out
Check the ping sensor, may be called knock sensor. Crank position sensor. And timing chain.If it was, it never said so on computer, ever no present codes, no stored codes.. nothing at all.. starts and runs great everytime , never got hot ..just a loss off power whenever I kick into passing gear.. engine was actually pinging real bad was scary was worried about permanent damage
Yes fuel pressure is good no leak downHave you put a Guage on fuel pressure?
Regulator, fuel pump???
How do I check ping sensor?Check the ping sensor, may be called knock sensor. Crank position sensor. And timing chain.
