Ridiculously cheap, ridiculously easy mods to consider
my eyebrow drip rail disappeared on our way to TN. Did not see it or hear it come off. It could be on the roof?
Suspecting the high humidity in FL did not allow it to stick well?
Did you clean with Isopropyl alcohol prior to adhesion? I cleaned with ISO then applied the section, moved ladder, cleaned with ISO then applied. So far so good. Surface prep is paramount.
Mine is still on, but now I have ANOTHER cracked windshield. Happened in Arkansas. In Idaho now with another 5 months to go before back home and replacement. Ah, the joys of life on the road.
I cleaned it with mineral spirits.
Uh-oh. I bought it, but have not gotten it on yet. This is my concern. I wonder if I should try double sided tape. The trim on my expedition, I found is held on by double sided tape - no screws or fasteners. Amazing.
Mine has been on for over two years with only one end coming loose about an inch. Put a touch of silicone glue on the end and no problem since. Mine is mounted on the windshield, not the cap. Been in 80+mph winds, freezing temps etc. and love the eyebrow strip.
Put a water pressure regulator inline aft of the city water reel. Never worry about pressure regulators again.
Amazon.com : Hourleey Garden Hose Repair Connector with Clamps, Fit for 3/4" or 5/8" Garden Hose Fitting, 2 Set : Garden & Outdoor
https://www.amazon.com/dp/B01N7JZTYX/?tag=rvf01-20
Good idea. I already left one regulator behind ?
Be careful to get all of the water out of it or bring it in during the winter. My $150 Watts regulator was destroyed.
Easy to pop out if needed but I'm fortunate to not have to winterize as I'm on power in storage and the wet bay will remain heated. Should blow out the system anyway and the average regulator is more on the lines of $30 I think, not a big loss. Convenience is key, absolutely love having this inline. Set and forget.
Note: This is not my original idea ... DW saw someone post it on Facebook and asked if I could make one so here is my version. If that person is here, please speak up.
It's a simple tray that sits on top of the front dash upper pull out drawer for drink cups and snacks while driving.
FLSteve
FLSteve
View attachment 3422View attachment 3423View attachment 3424View attachment 3425View attachment 3426View attachment 3427View attachment 3428
Well, that's very nice! Regardless of where the idea came from!
