- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
The latest 3D printing exercise...
When I replaced the original Sanicon hose with the reinforced version, the black floor filler ring did not fit on the new hose. While getting ready for our upcoming trip, I remembered the missing filler ring. 3D printing to the rescue...designed an interlocking 1/2" thick semicircle and printed 2 copies:
View attachment 2485View attachment 2486
I like it! I should have checked Thingiverse first.Here's my version:
RV Wet Bay Hole Cover for Sanicon Hose by NealC
I have a sani-con macerator pump system in my RV/motorhome wet bay in which I feed a hose through a hole to connect to the dump port. I want a cover plate to go around the empty area around the hose to prevent critters from coming in. I designed a cover plate that seals the area around the...www.thingiverse.com
Couldn't agree more....Fusion is SO fun to learn. I have completed a design and actually started over from scratch, just to try a new technique that can accomplish the same result in half the steps. Even though I won't have a 3D printer on our trip, I plan to spend a lot of time playing with Fusion.I try to design my own because I love learning Fusion and I have to learn Fusion. I balance the do my own and print what others have done. Your design looks great. I am very pleased with the one I did, it really works well.
Also, I need to figure out a better way to organize my files...still struggling with which files to keep and how to organize (GCODE or STL). If my Fusion files were better organized, could keep everything there and just re-generate when needed. @Neal Have you found a good source for how to organize the files?
@Neal, thanks. Do you generate the GCODE files to Dropbox and then copy to an SD card from there? I think maybe the SD card is what is messing me up...I generate from PrusaSlicer directly to the SD card(s) and end up with many test versions and a few final versions that then get lost in the SD shuffle.
Interesting...thanks again. Something more to think aboutI use a WiFi enabled SD card in the prusa so I can send the gcode files from my browser. I also have the Raspberry Pi setup so I can use that to upload the gcode and even start the print from there which is my latest option.
