The fun resumes…or not
Dennis, have you ever used the HB to do a regen?
Have not but have been through the procedure just in case.
Have used it to read and reset codes on a couple coaches though.
Friend was looking at it for work - they have to call Volvo to do forced regens at $800 a pop on their heavy equipment…
That’s crazy - the Diesel Laptops HD handheld will work for Volvo (I’ll check to see if that includes off road heavy equip) and they usually have them used for $300. But $800 for a regen is ridiculous- it takes 2-3 minutes to set up and an hour to wait for it to complete.
There might be something to that….as I have never had a regen incident (knock in wood) but I do make sure that I take the RV out for a 45 minute (interstate) drive every 30 days. This also lets me run the generator, oasis, etc on a regular basis. I feel like it is also good for the tires…
This ^^^
Regular running at HOT temps. Regular and long idling does not help, idling only makes the DPF problem worse.
Yes, I know truckers idle for long periods of time. Also know that most of these same truckers have a switch (like below pic) on their dashboard to start a regen, no special tool required. So accumulating some extra soot in the DPF is not a big deal.
Yes it is - from what he has said none of their heavy equipment actually does on on its own as they should. Would save them a bunch of money having something to start them on their own.
This ^^^
I’ve often thought about replacing my shorting plug with a switch on the dash (very simple job and there is room for an additional rocker switch). but I have never had the need to do a parked regen because I do forced regens proactively. Still it bugs me that every other type of vehicle with a HD diesel engine has the convenience of a regen switch, and for whatever reason, motor homes don’t.
I have the old analog DEF head...so, maybe...fingers crossed...I don't have these episodes..
This incident had nothing to do with the DEF head and the DEF head simulator would not have helped in this situation. The doser is down stream of the DEF head/tank.
As to the shorting plug, definitely something to know about and know how to use, I had to use it in my Breckenridge de-rate AFTER the Cummins service tech used his laptop to fix me up and the coach wanted another regen as soon as I departed, then never again. I pulled over, dove under the dash and disconnected/reconnected the plug below the OBD port. Never did it again. I tried it in this situation and it did not do a regen so it must not have needed one.
BREAK BREAK
I made it no issue on the long haul to Fond du Lac, WI today, everything was great. Thankfully no lights! I'll create a new post to discuss something @Rich W. and I talked about on the phone yesterday so others can learn from it as I was possibly doing something wrong on my starts. To the Cummins area for that now.
Well, the switch is on the Superstar - standard on the M2 chassis.
Can stop one in progress if needed as well as start one when the yellow light is on stating a regen is needed.
Does not do a parked one from the dash though unless the yellow light on that a regen is needed.
All as it should be. Maybe when I get everything else done on my coach list I’ll install a regen switch. Is yours spring loaded/momentary of just on/off?
I thought in 2024 Cummins / engine manufacturers were required to offer the ability to regen, etc. @redbaron I think you mentioned something about this some time ago?
The switch on our rig is a spring loaded momentary switch - and it has to be held for 5 or 10 seconds. Regen will not start instantly.
Perfect - that makes sense and is what I expected to hear. Thanks.
Yes, momentary switch to either cancel or start the regen.
Enforcement is another topic all together. NHTSA is responsible for enforcement and we all know how slow they are on some topics. Just depends how much feedback they get.
Well...my Ancel HD100 came yesterday.
I paired it with my phone via Ancel Trucker app. It communicates with the coach. It has a DPF Regen feature for the Cummins Engines...but I just can't bring myself into forcing an unnecessary regen. So, when the day comes...that I need to gorce a Regen, I guess I'll find out if it works or not. I had a technician force a regen back when the coach needed a new fuel injector...other than that...knock on wood...it has been doing a good job with passive regens.
The HD100 dis show me my soot load in the dpf is 0% right now... so, I guess the coach has been doing a good job on it's own.
I hope this tool is like insurance...there if you needed...but happy that you don't!
If you look i to these...careful that they have a HD 100, HD 110, HD 120... all do trouble codes, etc...but each model only does dpf regens for two engine mfg. It won't do you any good if you have one for International and Paccar...when your coach has a Cummins.
Awesome! Glad it seems to work. Very tempting…but I am in a holding pattern on whether to spend any major dollars on the coach…. Need to see what the next year brings. Will be curious if you ever need it.
And thanks for pointing out the model differences.
Rich
Or is it not reading the soot level? I need to first update my device, which I do from time to time, then see what it shows me. Glad you have something...and I think you can start a regen and then stop it soon after just to make sure you can perform one as @Rich W. just did in a comparison of information with me.
The odd things about soot level and it's a mystery is what is the level when a regen is needed? If you're reading it you may see values such as 200%. No clue on how these numbers are measured and what's really "in dire need" of regen status.
True…I have no track record with one of these things. I thought about starting and stopping…but don’t know how smart it would be to have it start dumping fuel into the ATS, and then stop the procedure with it un-burnt. Wish I knew more bout these things. My ‘98 Dodge didn’t have an after treatment system. And the Coach has been doing it’s thing without help from me…so far.
Hi @Chuggs ,
The Ancel HD100 (For Cummins)has a $50 coupon this morning (Amazon) bringing it back down to the $200 mark like on prime day. Is it worth getting? Sounds like you were pretty happy with it for the price.
Rich
I was just happy it paired and read data. I wish I could let you borrow mine to try out. I am happy to at least think I have a tool to let me start a forced regen, if I ever find myself needing to. I'm sure the ability for it to lookup codes will help out too...not having to call FTL-HELP.
Ok! Thanks Charlie!
