TXfreeze
- Jan 6, 2021
- Holiday Rambler
- Endeavor
- Roadmaster
- 350 Cummins
- None
- Yes
We recently got this coach and we have had no known issues with the shore power, today we had a hot plate plugged in on a 50 amp system not worrying about overloading the system but apparently we must have because we tripped the circuit that the refrigerator is on. After resetting the breaker the power did not come back. It's odd though because the air conditioning power is working and the microwave oven power is working. In addition to the GFC outlet that is by the bathroom sink and there is no reset response, The only outlets that are not working are the kitchen outlets and the dining room outlet and TV outlet which is pretty much all the front outlets. I thought maybe it was a bad breaker so I swapped out the 20 amp breaker for the water heater breaker and the frig breake, the water heater works just fine but still don't have any power so it's likely a short in the wiring? Will a RV repair be able to address this issue or do we need to call an electrician? One thing that I just remembered whenever the breaker for the refrigerator, is tripped whether it's on or off you can hear a distinct clicking sound coming from the breaker box on the right hand side of the circuit board with a green light what is that and could it be related to the issue? AttAched are a couple photos in case they help. Thanks
