Lithium Battery Wiring Diagram
I installed LiTime batteries this summer. I ordered them with Bluetooth and heating. I'm interested to see how the built in heaters perform in our Colorado winters.
Folks,
I am converting from lead acid to lithium batteries. Attached is how I plan to wire in the Lithium batteries. Let me know if you have recommendations as to what I should change.
thanks
Where is the converter connected and where is the solar charger connected (if used)?
Bob
what if you want to put 1 battery in the battery box and the other battery just inside the trailer...maybe 6 feet of wire?
Yes you can. Remember that charging and discharging cables should be spread between both batteries to equalize the load between the two.
what do you mean?
Your hookups should be split between the two batteries.
Positive on one battery, negative on the other. This maintains equal load/voltage at both batteries. In that way charging and discharging stays equal.
Hogwash! Cable length is important, but that can be handled by Cable routing.
