BobFolks,
I am converting from lead acid to lithium batteries. Attached is how I plan to wire in the Lithium batteries. Let me know if you have recommendations as to what I should change.
thanks
Where is the converter connected and where is the solar charger connected (if used)?
Yes you can. Remember that charging and discharging cables should be spread between both batteries to equalize the load between the two.what if you want to put 1 battery in the battery box and the other battery just inside the trailer...maybe 6 feet of wire?
