Rich-MLsRV
- Oct 1, 2020
- Colorado
- Ventana
- Freightliner
- 2020 Jeep Cherokee
Good to point out balancing current flow out of the batteries. Subtle important point to make. Thanks for commenting on this.Pulling power from the batteries the way your diagram is is the correct way. That helps ensure both batteries share the load. I cannot see ant issue with your plan.
Quick question. Do the 3/0 cables go thru any walls that may have metal? If so a fuse on the battery side is in order.
You may want to look at the cables between the batteries and your house connection. AM Solar shows 4/0 cable:
AM Solar 300Ah x 2
