Spruce Goose
- Oct 18, 2026
- Nevada
- London Aire
- Freightliner
- Cummins ISX15
- Ford F-150
- Yes
The capacitors were definitely bad. One of them was all puffed out. I’m thinking about adding the soft starts however I don’t think that would’ve fixed the original problem. The capacitors definitely have a lifespan and I think I reached it!Would adding soft starts have done the same thing?
Yes, mixed up terms.Pretty sure the PTCR is on a hard start, not a soft start.
Adding to this! Low voltage (Brown out), kills run capacitors. That is one of the best reasons for a auto transformer like the Hughes transformers many here use.Motor capacitors going bad is a symptom. Motor overload or insulation brake down, and insufficient voltage during start up. Compressor restarts with insufficient time for the pressure to bleed down also causes overloads.
You won't run an normal RV AC for very long on 200ah. Maybe an hour. I have 514ah and ideally can run continuous for about 3.5 to 4.5. I don't run it other then to test the system. It costs $$$ to run an AC for any amount of time.The capacitor point is what has me hesitating. I'm setting up a small camper in American Samoa and weighing whether to keep the stock capacitor arrangement or add a soft start, but the humidity and salt air here make me wonder how well any of it holds up long term. I came across LiTime 2-Pack 12V 100Ah Group 24 LiFePO4 Battery Review while comparing battery options, since the starting load ties into how the AC behaves on a modest bank. Has anyone run a Penguin II in a coastal climate and noticed capacitor failures?
