Dometic Air conditioners
Spruce Goose
Nevada
London Aire
Cummins ISX15
Ford F-150
2015 London Aire with the original units. two of them started making a loud humming noise at start up. I replaced the capacitors inside the control boxes.
Now they run smooth and quiet! we will see how long this lasts!
Would adding soft starts have done the same thing?
The capacitors were definitely bad. One of them was all puffed out. I’m thinking about adding the soft starts however I don’t think that would’ve fixed the original problem. The capacitors definitely have a lifespan and I think I reached it!
Motor capacitors going bad is a symptom. Motor overload or insulation brake down, and insufficient voltage during start up. Compressor restarts with insufficient time for the pressure to bleed down also causes overloads.
The Penquin II and Freshjet 5 both use a start/run capacitor for the Fan motor and Compressor...additionally another soft start capacitor with PTCR. If you install the MicroAir EasyStart...it has you abandon dometics small capacitor and PTCR and you still have to use the dual value run/start. The EasyStart helps regulate, but still uses that capacitor that came with the unit. So...definetly easy start or no...still have to keep a functioning capacitor there.
I know Dometic makes an upgraded Softstart...but I'm happy with my MicroAir EasyStarts...So, I don't know what it has with it.
Pretty sure the PTCR is on a hard start, not a soft start.
