J&JD
- Nov 3, 2019
- Fremont, California
- Dutch Star 4018
- 40’
- Freightliner
- Cummins ISL450
- Jeep Wrangler Sahara
Thank you Jerry. That helps. Hope I don't find some other mess in the back?And here’s the full panelView attachment 3120
All were tight, thank God!Thank you Jerry. That helps. Hope I don't find some other mess in the back?
BTW, were your screws tight when you checked them?
Exactly what I thought too. Newmar did the same thing on my Oasis wiring below. Used common spade slip on connectors on high voltage #10 wires, instead of crimp connectors.Just an add on here. that type of block is designed for lugs not house wiring. It is being improperly installed.
I will not disturb anything there until I have the replacement part in my hands. It can cause more problems that I don’t need right now.Pick the insulation and melted plastic off the terminals and take a pic for us.
