FYI Solar 101 - A General Guide to Solar in your RV or Motorhome
Scissor lift? In my dreams!!! Getting the panels up on the roof was the biggest hurdl.
The 6AWG works great. Early adopters were heck bent on parallel wiring of a bunch of 12v 100w panels. If I am not mistaken...AMSolar and Marvin Braun (PrecisionRV.com) were fans...and added thick cables from the roof to the basement. They have each diversifield since.
Yes...the 6AWG has it’s limitations, and as you point out...setting the panels in a series-parallel configuration will keep you within the amperage limits. I do not know the exact cutoff point..but at some voltage you go into “high voltage” category. In the solar industry...high voltage requires additional safety labels and manual shutoff switches...so I didn’t want to go there either.
Here’s a link that shows different configurations and formulas for calculating the theoretical voltage and amperage for choosing wires and fuses...
In a perfect world/perfect day...1,000 watts per meter sq. sun intensity...I would yield 1,440 watts (8 x 180watt panels). The math worked out nicely...if your batteries absorb setting is around 14.4v...1,440watts will give you 100A of current. My Interstate batteries recommend just a bit below that... ( C/10, or 92.8A). I wired my panels in four strings of two... So, each pair are wired in series...and each string of two are combined in parallel. It’s a balance. MPPT controllers love voltage...they wake up much faster with two panels in series...and can start working. The controller will have a recommended minimum voltage for best power point tracking. I advised another friend...he went with the Magnum PT-100 controller. I used the then current guidance in the Magnum Manual. They later found out the minimum voltage for their controller is higher than they originally thought. The controller works...but throws out an error code...which basically says the voltage is too low to compute maximum power point. I would recommend three panels in series for that controller based on the latest guidance...vs. two in series. During a high output point...I see somewhere around 1,200 watts...and the PV voltage is around 42v...and around 28A going down the 6AWG solar prep wire. The same gauge used in your cord reel to carry up to 50A. I believe the insulation they used on this solar prep wire is rated much higher than 50A...can’t remember what the amperage was that I found..but needless to say it is leaps and bounds more than 28A.
The way we use our coach...we have the minimum I would recommend. The atmosphere doesn’t always give you a full count of wattage. Having a residential refrigerator, microwave, espresso machine....we LIKE power. Seems a few of the high end installs lately have been closer to 2000watts and parallel charge controllers. Might fit on a 45’ coach nicely ?...
I do like not worrying about power outages, or being able to boondock and not running the Generator a huge amount. I also never worry about coming out to dead batteries. I‘m sure you are already onboard as to the advantages.
The 6AWG is great for what I have. If you were designing a system for 2,000 watts and parallel controllers...then two sets of 6AWG would have been my choice for solar prep.
The BMV-712 that you purchased can pair with certain SmartSolar charge controllers. They use proprietary VE.Smart (BLE) communication. With an optional temperature sensor designed for the BMV-712...the sampled voltage and temperature are relayed to the SmartSolar charge controller. If using Lead Acid chemistry...this is most beneficial as it give you more precise compensation of charge parameters based on battery temperature. LiFePO4...I gather uses no such temperature compensation...but can use the temperature in other ways....such as cutting off solar charge if the batteries get too cold.
I am a big fan of Victron solar products...
There is only to small a wire. The larger the better. If your wire is much above ambient temp you would better have been served with larger wire. Heat is lost power. use your IR thermometer. I have 4 wires coming from the roof, two for each controller in the rig. My MPP is 55 volts.
High voltage according to the NEC2017 is 100+ volts. under that is low voltage. The call of NEC2017 is for an E-shutoff switch that emergency responders have access to. In the past 48 volts was the limit at that voltage NEC had a say if the state adopted it. There is still the "preexisting work " for older systems.
Thank you for those details. I couldn’t remember what the voltage and safety cutoff requirements were/are...and haven’t stayed abreast of the latest.
So I’ve been trying to figure out some of the basic specs for the panels and the controller.
While I need to procure and install the panels and controller, there are several components that I already have. Those being the AGM batteries, Xantrex SW3012 inverter, AND the 6 AWG solar prep wires from the roof to the basement compartment.
Here are some thoughts. I’m looking for feedback to see if I’m think about this correctly.
My thought is that I want to develop a plan on how I would max out the solar capability. Whether I implement it now or incrementally over time.
It would seem that one of the implementation limitations will be the 6 AWG wire. Looking online, I find that a 6 AWG wire is limited to 55 amps (various based on temperature). If I were to install 12V panels in parallel, the output would be limited to roughly 660 watts (55A * 12V). Obviously I would want more capability than this. If the 12V panels were installed in a series of two and then each series in parallel, the 6 AWG wires could support approximately 1320 watts. That’s much better and in line with numbers that I’ve read in various posts.
I suppose I could combine the panels in a series of four to yield 48 volts and the 6 AWG wire could support unto 2640 watts. That sounds really nice! Am I understanding this correctly?
Also, it seems like panels are available in various voltages to include 12V, 24V, and 48V. If the input to the controller is going to be 48V, would it best to installed 4 12V panels in series, 2 24V panels in series, or just 48V panels. My understanding is that these would be options.
I also have a questions on selecting a MPPT controller, but I’ll post that latter as this post is probably long enough.
You need to use the data plate numbers from your desired panels. They will have Isc (Short Circuit Current)...and Voc (Voltage Open Circuit)...a 12v panel isn't putting out 12v... It appears you were estimating wattage based on 55A x 12V...doesn't work that way. I believe I linked a source pdf which details the computations...and application of safety factors...
@Neal
When you installed the panels on the roof did you add fuses between the panels and the combiner box?
In your picture the fuse beside the MPPT solar controller - Is that a 100A fuse?
@Neal
Yes I did and later removed them. You'll never know when one fails or in my case my crimps not being done good enough. AMSolar no longer uses them, I cut all of my out.
i have a 2002 Coachmen Class A motorhome. it currently has a 30amp shore power service with an Onan generator.
i want to add solar to be able to power the 120v service and charge the aux solar battery.
what inverter do i need to use and how do i tie it into the current coach inverter? can i still use the stock power panel and inverter?
i am doing this on the cheap. i have:
100w Harbor Freight solar panels and controller
Renogy Rover 30 Amp 12V/24V MPPT Solar Charge Controller
2 on/off toggle switches
a 3000w inverter
added 1 AGM battery
panels are mounted on the roof with the wires coming down the refrig vent.
Hard to say without knowing your setup, but why not just have your solar controller charge your house batteries. Solar is really just a battery charger….and then you use that stored power to run what you want (basically). You also did not say how much solar you have.
And why not use the inverter you have? 3000 watts is very adequate.
a 3000w inverter
added 1 AGM battery
Your my kind of person (on the cheap). We do have a different opinion of "on the cheap" however.
First things first! I would not run wires in a plenum (hot air vent cavity).
What I think you are asking is:
What do I need to do to power my house circuit on the cheap?
So this is the answer.
Disconnect the 110 vac wires from the converter. (Having the converter in the 110 circuit creates a loop).
Either run the power cord directly to the inverter, or wire an outlet from the inverter to the rv cord storage location so you can plug the coach in at that location. .
Hook up the charging system as defined in the solar controller paperwork.
Oversized wires are standard for solar. The controller should be as close to the batteries as is possible, and share the same temperature, not the same compartment.
One final point! DO NOT MIX AND MATCH BATTERY TYPES, OR DIFFERENT BATTERY SIZES! ALSO ALL BATTERIES SHOULD HAVE MANUFACTURED DATES WITHIN 6 MONTHS OF EACH OTHER. The old will destroy the new.
I am not a solar expert but I have learned a lot from others here mainly @Chuggs who guided me through my solar install which I mirrored his setup and then took it a few steps further. I wanted to share what I have learned to date as it may help others and I welcome others that also installed solar to add your opinions, correct me where necessary, and help to educate the RV community with where we are with solar as of this writing closing out 2019. These are only my opinions, it's okay if you don't agree, take from this what you want, discard what you don't want. I am writing this based on my knowledge of my coach brand - Newmar, others may vary.
Solar Prep
If you have the opportunity to order your coach you may be presented with an option to add solar prep. In my opinion everyone should add this option whether you intend to add solar or not. The next owner or owner after that may want to add solar and having these few wires run at build time will sure make adding solar an easier endeavor. At the time of ordering your coach you may have no plan to ever use solar and later change your mind. Not getting your coach solar prepped would be a huge mistake.
Solar prep is nothing more than running a positive and negative 6 AWG wire to your roof in addition to an ethernet cable run from your basement to your inverter control head inside the coach. These wires will be coiled and attached to a basement wall.
Why Solar
Solar is a battery charger, nothing more. When your RV is not powered by shore power the batteries are doing all of the work via your inverter and supplying the power as configured. Most of our motorhomes come with outstanding generators such as the ONAN QD8000 in my Newmar Ventana. These generators are often under utilized and will serve the needs to power your motorhome or RV in the event there is no shore power. Depending on the inverter controller you have there are various settings you can take advantage of as to when the generator comes on and how long it runs. The generator also serves as a battery charger but also works to supply electricity in the same way shore power does. So if we have these generators why would we ever want solar? There are benefits of solar such as not burning fuel to run a generator or making noise in a peaceful camping situation. Other scenarios include blending shore power with solar such as when I was recently at a 30 AMP campground I could use shore power to supply my air conditioners and solar to provide the source of power for all inverter supplied loads. An additional scenario is keeping your batteries charged when in storage or in for service. Advanced coaches these days have such high electrical loads then sitting in a service lot such as Cummins when not connected to shore power will kill your batteries if not disconnected and may damage your batteries requiring you to replace all of your house batteries which could be near half the cost of a solar install. Another scenario for solar which I'll be using in a few weeks is a long term stay at a campground that charges for electricity. I'll have my MH setup so that solar supplies all of my electrical demands until the batteries get to a certain percentage of charge and then shore power will come online if solar is not doing the job. So there are many reasons for solar and the amount of solar installed depends on your usage scenarios. If just keeping batteries charged while in storage you could require fewer panels such as just two panels on the roof. If you want to keep your refer on such as was one of my requirements for solar before I moved to a storage facility with shore power it was determined I needed a minimum of 1440W of solar.
What is involved in installing Solar
Believe it or not solar is not complicated. You can do it yourself as I did mine as long as you are educated and/or coached by someone else that has done it. You can have it professionally installed as well and I highly recommend AMSolar.com as they were very helpful at the time of my solar setup in determining minimum loads for my demands, what hardware to buy, etc. If you can get on your roof you can do this yourself, it's best to have someone help you even though I did mine solo. Getting the panels on the roof is the hardest part. As with everything these days YouTube is a great resource for learning something prior to doing it. Search YouTube for your topics of interest and get educated. AMSolar has great videos as well which I watched prior to my install.
Solar from top to bottom starts with the panels. You can get panels of various sizes based on your needs and available space. You'll want to design a layout so that you can still walk on your roof as needed. You can get solar panels from various supplies from AMSolar.com to Home Depot, etc. In fact you can get refurb or blemished ones from AMSolar I later learned when I needed two more and save quite a bit of money so don't hesitate to ask about that if you're okay with it. They still work the same but may have a scratch on the glass that prevents them from being sold as new. In the configuration @Chuggs designed to go against a MPPT type solar charger he designed the setup so that two solar panels were paired together to increase the voltage going to the solar charger effectively doubling it by putting the two panels in a series configuration. Each pair of panels then gets wired into what is called a combiner box which sits right on top of the area where your RV manufacturer left the ends of the wires underneath your roof. In the case of Newmar they put a metal plate over top of the area where the two wires should be. Keyword "should be". Cut carefully into the roof below this panel only large enough as needed to start looking for these wires. Don't go too deep either only cutting through the thickness needed to get through the roof material, there was a duct below my location. The two wires were about 6 inches offset from where Newmar indicated they would be, I then pulled them up and connected them to the combiner box. Each pair of panels is also connected to this combiner box and then you're essentially done on the roof after mounting the panels per the guidance of your solar coach or manufacturer. In my case it was simply a matter of cleaning the fiberglass with a mild abrasive scotchbrite pad, then 91% ISO alcohol, then adding 3M primer and using the adhesive mounts to attach to the fiberglass roof. You can also screw them down if needed but it's not necessary. Then add dicor around the mounts to keep the elements from breaking down the adhesive connection.
Now that the roof is done and the panels are attached to the roof and the wires are connected to the combiner box the power is now ready to be connected below. Obviously you want to protect the ends of your solar prep 6 AWG wires as you now have electricity flowing. I mounted all of my solar components to a board and then screwed the board to the sidewall of the basement. A mistake I made was the location of this install. I elected to install between the chassis rails and as I later got HWH Active Air installed it interfered with the location where the leveler sensor should have been mounted. With that said consider mounting your solar components near the basement door i.e. not between the chassis rails.
My coach has a Magnum 2812 inverter. Some choose to remain with Magnum components such as the PT100 but @Chuggs made a great decision to go with someone a little more cutting edge with bluetooth functionality, the ability to easily update the firmware, and an array of other components that all play well together. Per @Chuggs I went with a Victron Energy MPPT 150|100-tr solar charger. In the image below you can see this "blue box" but let's follow the flow of voltage. As you can see with the red arrow the positive from the roof is coming into a catastrophic fuse that will protect the components such as a voltage spike, lighting strike, etc. This cable then goes into the charge controller. The negative comes into the black power cutoff switch and into the charger controller allowing you to isolate (cutoff) the power flow from the roof panels if you need to such as doing some work on the solar charge controller or simply turning off your roof panels. The blue arrow indicates the flow which is going from the solar charge controller to the battery bank I believe using a 2 AWG cable and going through another cutoff switch to cut power to the charge controller and stop the flow to the battery bank. As you can see this is a very simple setup, nothing cosmic here, this is solar!
A few additional components are involved to improve the entire battery charging experience. As you can see in the photo below with the solar charge controller on the left side is a Magnum Battery Monitor Kit (ME-BMK) which measures the electricity flow through a shunt. Installing this shunt is a little complex in that you need to know how to install this carefully so as not to damage your inverter. Follow the instructions, research the web, or have a professional install it. The ME-BMK works well with the improved Magnum control head called the ME-ARC50 (A is for advanced, i.e. advanced controller) which works better with solar (PT100) and BMK components networked together. As some of us elected to go the Victron Energy path we opted to also add a battery monitor that the Victron system can use which is the BMV-712. The BMV shunt can be shared by the ME-BMK so you can have a single shunt in use that provides the information to the solar setup and also the Magnum control head. The BMV-712 also has a battery temperature sensor you can buy so the solar system can do automatic compensation based on battery temps such as in extreme hot or cold locations. Another item we added is the Venus GX which is a networking controller that provides data to the free Victron Energy Remote Management cloud portal (VRM). This allows you to view your solar data from anywhere using a computer or smartphone but also to configure alerts such as if your batteries go below a certain charge state, etc. You can also add a temperature sensor to the Venus GX to monitor items such as I use it to monitor my wet bay temperature and have alarms should the temp get below a certain point.
Conclusion
Solar is a great way to really learn the electrics of your RV/motorhome but also as described above to avoid being in situations where your batteries can be damaged by not being properly charged when out of your control. You'll better understand your house batteries and their capabilities, your inverter, and your shore power and how all this comes together to provide the needed electricity for your coaches demands. In addition if you decide to add MicroAir Soft Start units to your air conditioners as some of us have done and do a little more electrical work you can actually run an AC off of solar which is cool. That's for another discussion.
I've seen some great solar installs and learned so much from others on forums such as this. Several have even gone the lithium route and if you ever cross paths with @10 fan you should look at his lithium and solar setup where he installed two PT100 charge controllers and has both legs of his power supplied by solar allowing him to do anything that you can do with shore power. Amazing! Impressive install and design!
Feel free to ask any questions but again this is really designed to be an intro to solar with some usage scenarios but also not to be intimidated by solar as it can be a great asset to have on your RV. It is amazing how much power you can draw from the sun, with my 1800W setup (10 x 180W panels) I can easily sustain 100A of power from the roof which is the limit of my solar charge controller.
Dear Neal--
Thank you for this informative Solar 101 discussion. I own a 2017 Ventana as well although mine is a 3709 model. I'd guess I have a little less room for roof panels but all I really need to do is run my Whirlpool residential size fridge which I'll bet is the same one as yours. We summer at 9200 feet in the Rockies so A/C is not needed.
I will be following your advice and gaining some basic knowledge before I jump in. Anything else you'd like to share would be most welcomed.
Laurent Perron aka notsotallTexan
San Antonio, TX.
I managed to fit five residential 315w panels (33v, 9.5a) on my ’16 3427 but had to remove the winegard dish to make room (never used it anyway). It would be easier on a 3709 with a few more feet of roof. And yes, enough solar, inverter, and battery bank to run an AC effectively is a fairly major undertaking (did it on my Bay Star) so rather than invest and go through all that again, I just stay out of hot areas with no hook-ups.
I'm a newbie in my hope of replacing my battery bank to Lithium batteries and also installing solar panels on the roof of my 2017 Ventana. I appreciate all of the help on this forum especially from Neal. One thing I'm puzzled about is why one needs to go with a new inverter when my RV has a Magnum 2812 inverter.
I didn't change my inverter, not required.
Same here...still using my 2812.
It's all about the numbers. To do it right you have to build according to the numbers.
Check the recommended charging voltage for the battery's (bulk charge). Compare with the kick out voltage of the inverter. If the two are compatible, there is no reason to replace the inverter. The controller needs to be setup properly to avoid the inverter kicking out as well.
Okay, thanks! That's great information. I'd like to put together a list of what I intend to purchase and then post it so you knowledgeable folks can let me know if I'm missing anything.
Thanks again!
Laurent
Thanks Kevin!
Dear Neal--
San Antonio, TX.
Dear Neal-- I've been getting good information from Jack Caruso at AMSolar. I sent him a link to your great post on the forum. Regarding my wish to use my Magnum Inverter, Jack said: Lots of good info in the RV forum link. One thing I will add is that yes it is possible to get an older Magnum unit to be Lithium safe and quasi brute force it for lithium re-bulk charging. The short is that it depends on the Revision # of the inverter unit and what level of customization it has with an ARC 50 according to this table. For your unit you are looking for ≥ Rev 5.4. What you may find you have to do is set the equalization button for your re-bulk voltage and hold down equalization when plugged in to initiate the last 20-15% SoC of charging.
Neal, did you find out what revision # your Magnum is? I attached the ARC 50 table that Jack made reference to.
I'm not using LifePO4 "yet" still FLA in my coach.
