Question Best Water disconnect
sheridany
Orinda, CA
I am looking for water quick disconnects and I remember a particular brand as the best ones to use. Somehow I seem to remember someone posting on this topic over “there” and could not find the thread.
This is what I use:
https://www.amazon.com/gp/product/B01IDHCL58/?tag=rvf01-20
I prefer and use these from the RV Water Filter Store:
Tried the less expensive garden hose quick disconnect fittings and they leaked badly. YMMV
Just have to remember to take the disconnects off the spigot as you leave :rolleyes:
I agree with TJ on this style...for another HUGE reason: The ones, with the rubber ring, you get from Lowes and/or HomeDepot have an auto-stop plate in them that really restricts the flow.
If you look around, you can find the ones that are open bore.
Sent from my iPad using Tapatalk
Actually, I need to remember to take my pressure regulator off the spigot as I leave. My quick disconnects are on the hose and output side of the regulator that screws onto the spigot. So far, I haven't forgotten, but have had a couple of near misses. It helps when you have a detail-oriented co-driver like LadyDi. She has saved the day more than once.
I try to have the same routine every time we break camp so that everything gets done in a certain order.
I have a couple of places that need 90 degree quick connects, and these work very well..
Hmmmm, that little 90 box looks intriguing. Thanks.
The best are the ones from the Water Filter store.
Ditto! I like the Kwik Link. I also have some brass ones that I got from Amazon and they work well too.
GORILLA EASY CONNECT Garden Hose Quick Connect Fittings. ¾ Inch GHT Solid Brass. 4 Sets of Male & Female Connectors.
by Nine40e Corp
Learn more: https://www.amazon.com/dp/B06Y4YYXYN/?tag=rvf01-20
The Water Filter Store used to sell a 75-degree version of the angled quick-disconnect male fitting, but I don't see them listed any more. I have a couple and they are quite handy where the 90-degree version might be just a bit too tight.
Actually, the 75 degree ones are what I have, but I can’t find them anymore, either. Needless to say, they will not be traded in with my old coach!
I use the same ones @Neal posted which I got from lowes. If/when one breaks, I will check out the ones from RV Water Filter Store. They can leak but it was quickly resolved with a bit of plumbing tape.
To prevent myself from leaving anything behind I have mine setup as water source —> Brass Y with shut offs. On each shutoff, I have a quick connect. On the first Y valve, I have quick connect to to my water softener’s input. Coming out of the water softener, I have my pressure regulator, with a quick connect coming out of that and into the RV hose. To cap the RV hose when it’s time to pack up, I replaced the attached white plastic cap with matching quick connect and put a brass plug on it so I can quick connect the plug, giving me a barrier to prevent contamination while in transit.
When it’s time to go:
1. unscrew the hose Y from the spigot and disconnect it from the water softener.
2. Disinfect with a spray of Clorox bleach (just courtesy and always disinfect when I arrive)
3. Use the quick connects on the softener to connect its input hose to the output of the pressure regulator on the other end, creating a closed circuit on the softener to prevent contamination.
4. Cap the RV hose with the attached quick connect that has a brass plug.
5. Pull the hose in, holding a towel in your hand and guiding the hose through your hand to give it a wipe down as it comes in.
6. Stow the water softener and hose Y.
The hose Y is also really helpful for relieving pressure when it’s time to disconnect. Just shut off water spigot and open the second valve on the Y.
Also have a quick connect on my water hose for rinsing off which I can quickly attach to the second hose Y valve. My paint is too new for anything more than that until January.
These are what I use and found that they have less restriction than the metal ones and a positive connection. The only downside is the cost. These are 3/4 inch without any kind of restrictions and I have never had one leak.
I didn't realize that Banjo made them in that size, and with hose bib threads. Interesting!
