FYI Newmar just doesn’t seem to get it!
Those outlets should be on a breaker.
They are, but I presume you mean by themselves, in which case I agree.
I don’t understand how Newmar was able to make certain that my jacks won’t work when the engine is off but to do the same for the the awnings is somehow a mystery.
Following an engineering spec I presume. Did Girard direct this "feature"? Go back to Girard and ask them if they directed Newmar to wire an engine disconnect. Newmar may not be at fault here.
Girard provides an ignition lockout with their awnings. I doubt they do so for Newmar to ignore it. So either Newmar isn’t installing it properly on some coaches, or they are and it doesn’t work properly.
hopefully @TJ&LadyDi will fill us in once his humpty is made dumpty again by Girard
We will be asking a lot of “Humpty Dumpty” questions and will definitely report the answers we get. Pretty obviously, the ignition interlock in our coach (if it was installed) didn’t work in at least one instance. Whether that was due to (a) it not being installed by Newmar, (b) not being properly wired by Newmar or (c) a defective unit provided by Girard to Newmar is unknown at this point.
Let me reiterate, however, that I get the sense Girard is genuinely concerned about what caused our awning to extend and wants to find the answer. They have been great to work with thus far and I’m convinced that will continue.
I have little tolerance for corporations who take $500K of my money and then consider "unplugging the plug" as a reasonable alternative to experiencing a disastrous mishap.
You would be amazed at the number of people I’ve heard from who think my frustration with Newmar over this is completely unreasonable. And, very few of them are Newmar owners. Interesting.
Fortunately, Girard has been great about stepping up, and I’m confident the issue will be resolved satisfactorily. I still have not received any response directly from Newmar.
I suppose rotating the outlet would be an option. That would put the switch on the outboard side.
This looks like a quick solution for switching the awning plugs:
Ours must be different than all the others, because on my panel above drivers position, I have awning panel, one switch off/on; one switch extend/retract; one switch wind sensor, high/medium/low. We have never had awning extend going down road, as I turn off switch as part of pre-departure check list. Normally, we don't use awning much anyway, berceuse I don't want to lose it if wind just does a wonkey thing.
FWIW-This will be our last Motorhome/RV period. The lifestyle/experience has lost it's allure because of many factors, not the least of which is impossibly of making a trip plan and getting into the places we want to get into, the rudeness of fellow campers. But mostly, the number of people who now own them and are just too stupid to do so, and no I am not talking about a "learning curve" actually the intelligence quotient needed to operate a large vehicle safely and professionally.
Not to get OT. But my friend, this is modern society. It’s not just camping or RV ownership. It’s the programming that we are installing into people. It’s the lack of common sense. Quite scary actually.
Mike.
As example, in the early 1900's, parents taught their kids responsibility, how to "do stuff", work, properly take care of themselves, operate a gun safely. Today, the parents let the schools do it, because that is how they were raised. We are seeing a large swath of society, untrained in life, hence as stated not got a lick of sense. RV'ing is something you can learn how to do, but, it takes money and time. If you think I'm wrong, find any boat launch and watch the circus on almost any busy day. Dealers/manufacturers are at fault as much as anyone, they care about one thing only "MONEY", the customer and end user is second best in the process. People used to want to "learn how stuff works", today if it's not on their phone, they aint got a clue. Oh, as we age, the vast majority of people who RV will continue to decline in knowledge of courtesy, and helpfulness. If you think about this look along side of the road and all the trash there, but we all know not to litter, now where did all that trash come from?
I read this and felt a little sad. You add so much to this site. There are still good people out there to meet and enjoy. What ever it is you choose, good luck and enjoy life.
We are going to use it this summer and see how things go,. so far getting a park at our schedule is problematic to some degree. MH works great.
I have just planned my trip from la to Indianapolis and returning thru Idaho and down. I booked every place. No problem. Mostly upscale but not all. I use Upscale luxury RV resorts for most. Enjoy your summer.
One thing to remember is that these are not “normal times.” It is all-too-easy to get discouraged in times like these, but we have faith that the situation will improve reasonably soon. Let conditions stabilize before you make any final decisions.
