- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
Is your warranty period still active? I thought it was only for 3 years. Perhaps you got your coach late in the model year. Mine expired 6 months ago.This should all be under warranty AFAIK. If not, I’ll drag out the checkbook.
You should be able to access the fault code on the Spartan message bar and on the Silverleaf console display. I believe it’s available under the chassis screens. Recently I had my ACC disabled due to an ABS wheel sensor issue which was easily resolved.The ”check engine“ light is now on and the regular cruise control is disabled.
Are you talking about the “RV-C diagnostic codes?” If so, it says “No Faults” but I still have a Check Engine light showing.Is your warranty period still active? I thought it was only for 3 years. Perhaps you got your coach late in the model year. Mine expired 6 months ago.
