MapNerd
Eric or Josh at Roadmaster could make a mount if they had a truck to work with. He just needs an attachment point on tie rod or drag link and a clear shot to the frame. It is not Rocket Science. We did F350 and F450 and Ram 5500 all 4wd. those three take a longer unit Roadmaster needs to build. I think F-150 has the same travel as E-350 and E-450 and Wrangler. Roadmaster has a few hundred employees so some one is sure to have a F-150. Josh has 100 MM units 5.93" of total travel, He has stock I think in February for 350 and up that need 150MM. Two wheel drive and independent front suspensions will take a bit of learning, but Roadmaster has plans for both for their towbar customers.
here is a link to more backing video.
Exact Center Backing 093021 R2 music.mp4
there is a lot of backing here.
Here is more from Roadmaster explaining how the device works. It is very simple. Put your fist together and push, then have a grand kid or some one pull from each side. The Exact Center is your fists pushing hard. On big RV's we had over 350 pounds pressure, that is like having two line backers holding your steering. I went smaller and now have a Dynamax Isatta 5 28ss explorer 4WD. On it I am now at 220 lbs and I will go higher in the spring. On the big units it is hard to get too much pressure because the power steering is so large. On a Wrangler you could get too a heavy feel. Maybe at 150 lbs on your F-150 steering might be stiffer than you would like. On the big rigs (big light boxes) more pressure when right will make the wind go away. On a 39 foot Freightliner Super C it took 330 lbs and with that I could drive through just about anything. My 2018 Rubicon at 75 lbs was just right. We towed that to Roadmaster in Oregon. My son has the JK you will see behind the Class C backing he likes 75 lbs. Roadmaster will be able to raise the pressure real soon. Their tools are almost ready.
