Help Dead Battery!
Go back to the 300 amp fuse. I may have miss-stated the continuity meter method. Not sure if that actually checks a fuse or not. I think you might need to check both sides of the fuse to make sure it has power like someone else said. Maybe RedBaron can weigh in on that because he knows more about fuses than l will ever know.
A multi meter has a continuity mode to beep if connection is made. This will test the fuse. You put a lead on each end and it will beep or show continuity if fuse is good .
He's all electric, VTDP 43 footer
Then there are 3 reset buttons..hard to see but they are there. This is the problem.
Remember these are installed upside down between the rails. Look at the picture, it will be up high closest to the ceiling of the bay in the corner. Very hard to access. The single button bear the lights is NOT the right one.
Sounds to me he came back and he hit LBCO. Why he wasn't charging is the question.
Chassis batteries are ODS in the rear.
House batteries on DS in the front.
I tested the voltage on the house batteries.
Also, I know it’s the house batteries because my chassis batteries are AGM and don’t take water. I knew it would change anything but made sure the matter idea wouldn’t take more water via the watering kit I installed a few months back.
Tank level gauge shows my batteries be good. Which makes sense per what @redbaron said. Attached a pic.
No the charge button does nothing. Just mocks me.
I think he did charge, his batteries are 6.4 volts. That's 12.8v per pair.
I think he has a simple blown circuit.
This is correct. Newmar called back. No idea. Call us in the morning. Transfer switch sounds plausible.
With these breakers flipped, nothing that is on the inverter will work.
This means washer dryer and ac will work, as will the Oasis heater and stove.
Microwave and all outlets will not work.
**update** @nealc sent me a picture that @MapNerd sent him. His 2812 only had 1 breaker, and 2 studs.
We suspect the 300amp fuse
Just got off the phone with @MapNerd so we'll resume to the forum. Here are the pics he texted me.
Notice in the pic the green light is OFF? @MapNerd go back to the inverter and press the on/off button again after recycling the breaker as we did.
@Neal Did that. It doesn’t turn on
Press and hold for 15 seconds?
I just went out to mine again and felt up there. I have 3 buttons...until I look at it with phone.
I have 2 screws and 1 breaker. I have had to reset multiple times but the breaker was the only one. I thought I was pressing 3 breakers but obviously I was pressing 2 screws and 1 breaker.
It’s 11:19pm here though so we’re calling it. We’re in southern FL so nothing will freeze. Gonna give Newmar a call in the morning and go hunt down a 300amp fuse. Look for a new thread tomorrow with me asking how to safely replace a 300amp fuse without killing myself
