- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
A multi meter has a continuity mode to beep if connection is made. This will test the fuse. You put a lead on each end and it will beep or show continuity if fuse is good .Go back to the 300 amp fuse. I may have miss-stated the continuity meter method. Not sure if that actually checks a fuse or not. I think you might need to check both sides of the fuse to make sure it has power like someone else said. Maybe RedBaron can weigh in on that because he knows more about fuses than l will ever know.
Sent from my iPhone using Tapatalk
