Chargerman
RVF VIP
- Dec 26, 2019
- Monaco
- Executive
- Roadmaster
- Detroit 60 Series
- GMC Sierra 2500
@redbaron ... I know you have posted the part numbers for your coach. Did you determine and buy those yourself or did Centramatics figure out which ones fit your coach and get them?With taxes I paid $732.00 installed.
I am in a similar situation so was wondering the same thing. Maybe I will see you there.Given the obviously reasonable labor rate, a couple questions:
1. Was there much of a wait for an appointment?
2. Did you have it done in Alvarado?
Im going to be in Austin for nearly a week for a wedding with a lot of down time between three short events. So a trip to Centramatics and back would make good use of a full day otherwise spent sitting around eating and drinking and telling stories that have already been told. And my old tires would probably appreciate it as well as the moving parts of my suspension.
the hair thing is a bridge too far for me to follow way too much time on your hands ;=)) good luckI posted only a few days ago about it not being the time to buy. The sentiment was in regards to a USED rv, and also USED vehicles.
The same sentiment is true for purchasing NEW - On the lot RV's from most dealers. I did, however, find an exception to the rule.
Newmar coaches have already started to trend down on sales. Dealers are wanting to sell specific models. There are a few models that have sold out, but for those with a higher budget in mind (Luxury line), the deals are actually better now than they have been in a while.
July 16, 2021 Newmar is doing a 2% price increase on all diesel product, and will no longer guarantee price protection for orders placed after July 16, 2021. This is something that others in the industry have already implemented, and it makes sense.
Newmar has also changed the entire order process slightly. In the good old days of "pre-covid", dealers would buy out all the coaches they could and have blanket orders in the build slots that would then be customized. This allowed the dealer to know exactly when it was coming in, and then make changes last minute.
This practice alone was a huge disruption to the supply chain, and it is amazing that Newmar allowed it to go on for as long as they did. Most likely the push back by dealers was too much to upset, so Newmar dealt with it, as did the customer.
Why the customer? Think about it--if everyday you come to work knowing that someone is going to run up to you with a yellow sticky note telling you to change something, yet you still have to produce the same amount of product...how is that even possible?
I know that orders never where changed once they entered building 7, but they did change while still in the chassis shop. The person making changes had to find the product from somewhere, and this chaos has trickle down effect.
When covid hit, the entire supply chain halted. Not only could custom orders not be fulfilled, but stock orders couldn't either..parts where a huge nightmare.
So the new process is this: A deal must be signed by customer, including paint, blueprints, and specials. Only after all are signed can the build be assigned a coach number, chassis vin, and production run. Dealers know that they have x amount of chassis available in each run, but if they fail to turn in an order, then a dealer in the runs after them with an order ready to go will be moved up, and the dealer will take the back of the list.
Once you sign off, there is still a very small window to make changes. If you do make changes, your vin / build will be canceled, and the process starts over. You will most certainly lose your slot assignment.
After the small window passes, you and your dealer are legally bound to the coach as you signed off on it.
You are at risk for your deposit, and your dealer will have to purchase the coach and put it on their lot for someone else to sell.
Now to my situation. @ARD started looking at 2022 DSDP coaches, and I was helping her with paint schemes. Newmar did a terrible job with the 2022 Dutchstar pattern, especially at the rear of the coach. No matter how you color it, the rear looks like an homage to Donald Trump's hair....look at it:
View attachment 7827View attachment 7828View attachment 7829
I could not unsee it after I said it---and I don't think Renee could either.
She then flipped to the London Aire. I got to wondering why she would make that jump. I have always said my next model up would be the LA, but I figured I had a few Dutch Stars left in me before that big jump.
The answer revealed it self as I started pricing. For my coach, the net difference between selling my 2019 DSDP and buying the 2022 LA4551 is $200k - $235k. I don't know exactly as I have not sold my 2019 yet, and I have not received final pricing on the specials.
That price difference is in line with the difference in buying a new 2022 DSDP today vs a 2022 LADP, which means I did not take a depreciation hit. That doesn't happen---ever, and so this became the right time to buy.
More about the build to come...still working on the final selection items and waiting to sign off on my deal sheet.
@redbaron ... so when you install these does it push the rims outward a little bit on the tire studs? Just wondering if I will have any clearance issues if the tire is already close to the edge of the wheel well when not aired up.The guys at the factory figured it out. They had been selling the steer axle part numbers for the tag.
When installed on the tag, it was pushed against the wheel very tight.
The correct part has an inch gap.
The thickness is 1/8". It is not a noticable difference.@redbaron ... so when you install these does it push the rims outward a little bit on the tire studs? Just wondering if I will have any clearance issues if the tire is already close to the edge of the wheel well when not aired up.
FLSteve![]()
We just made it to the Centramatics factory parking lot ... installation of my balancers will be first thing tomorrow morning.Getting my centramatics installed at the factory.
