Joe Dutchstar
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
Hi Joe! If I reset my mileage meter when I start out, and I drive for 5-6 hours (in Florida), I'll finally get to where the meter is showing 7. So I would say you're probably getting pretty good mileage.On our recent trip down from Newmar, the DSDP averaged slightly more than 7 mpg. Around 45.5K in weight towing a Ford Flex.
Normal? Or does this engine need more than 1200 miles to get true Average Fuel Stats?
An add! Any change in fueling pad level, and you would need to count for surface area in tank.I don't know how much "space" foam displaces but IMHO if you want to get an accurate mileage assessment, you should slow fill to full avoiding foam, drive a route that's near level and get the fuel level as low as you can stand, then slow fill again to avoid the foam, then measure your result. I think we all know it's something around 7 for these beasts, beyond that I stop counting or worrying. The biggest thing is trusting your fuel gauge. This last leg home I had to put that trust to work and arrive at the fuel station in "ding" mode (low fuel alerts) and even still, I had 20 gals (out of 100) remaining after a slow fill. Mine calibrated/checked good. I did have to have a sending unit (or something along that line) replaced about two years ago from the fuel gauge going wonky on me.
