DennisT
- Dec 1, 2022
- Superstar 4061
- FCCC
- Cummins 360
- 2022 Jeep Cherokee TrailHawk
- Yes
Yep, we averaged 6 through Wyoming last fall, going west, about 8 heading east, strong westerly winds in WyomingIf you do much traveling in the mountainous west expect to see at least a 10-12% drop from the numbers you are seeing at a minimum.
Strong wind current from the west, always, from the Mississippi to the coast. Also the rise in elevation. The trip home should almost average out!!!Yep, we averaged 6 through Wyoming last fall, going west, about 8 heading east, strong westerly winds in Wyoming
You must of been using Premium at those prices or was it diesel? Also curious, speed???They do go up as you get more miles.
I use Road Trip app, saves data to iCloud account instead of another.
Last year headed to FL for winter.
That was the pump price for diesel and they were discounted after using the EFS card.You must of been using Premium at those prices or was it diesel? Also curious, speed???
Damn you would bring up tank level!!!@Joe Hogan I suggest performing this test. Diesel fuel, especially at the high rate of a truck pump can generate a lot of foam and easily throw off your mileage calculations.
Stop 1: At about 20 gals prior to full slow down your fill speed to about half. With around 10 gals remaining, slow it further. Goal is to minimize foam. Maybe even wait a minute or so and then try to get as much diesel in as possible to ensure a full tank.
Stop 2: Repeat above. Now measure your mileage. Report results.
100% Neal, agreed there are so many variables. One big one you brought up about fuel-fill rate and foam, on a 100 or 150 gallon tank a slant on the isle could equal a significant difference in volume. Earlier in this thread generator and Oasis fuel consumption came up, I believe the MPG calculations are simple tank float level fuel volume Divided by miles driven, so if your cranking 3 AC’s running the generator cruising down the road on. 100 degree day your MPG will suffer.@Joe Hogan I suggest performing this test. Diesel fuel, especially at the high rate of a truck pump can generate a lot of foam and easily throw off your mileage calculations.
