Black Tank Sensor
ARD
Staff member
RVF Moderator
Fulltiming
London Aire 4551
Yukon Denali
Can I just say Hallelujah! Newmar is done with KIB. As many of you know, I, as many others, have had issues with my black tank sensors reading properly from year 1. I've had new sensors, water pump relocated, new board, software updates, tons of recalibrations to no avail. This past visit to Newmar has taken care of my problem. Newmar unplugged the KIB pad on the tank and installed a a sensor by the gate valve that works by pressure (gravity). The higher the water level, the more pressure you have. It is working so far. No red lights, no showing 100% full when empty. It's the little things! Oh and the floater is still in the tank, so IF you do get a full tank reading when you think it's not full, you can pull the famous yellow wire and if it is still red, you know you are full. ?
Can you post a picture of the new sensor? Does it still send data to your kib display for tank readings?
Ah, good question. My display works and seems to be very accurate. Yay. The pad on side of tank is disconnected, but the floater still works. Dang, I didn't ask how the readings were getting to the display. I'll send a photo in the morning.
Just emptied my tank and it says 0%. Is this sad that this makes me so happy? ?
This device makes more sense than any other device I have seen!!!
Its a simple pressure switch. Failure is easy to fix, and accuracy is all but guaranteed. Amazing.
I'm more concerned about the floaters ?
For those wondering about the picture, this looks to be just ahead of the gate valve. I'm curious how it can really sense pressure differentials and know percentages especially between what goes in black vs. gray. I can understand a no/low pressure, i.e. an empty reading but above that I'm curious.
Take a look at this description of the process.
This is such an obvious design Improvement, I don't know why this hasn't been done before now.
Based on Newgle, it looks like Newmar started using the Kavlico pressure sensor in 2011 and moved it down to the next model each year and by 2015 all of the luxury models were using it. I’m guessing they did not introduce it to the Dutch Star on down models as a way to maintain the difference in the various models. Perhaps also due to the tie-in with Silverleaf.
Given that Newmar has retrofitted Renee’s coach with a pressure sensor, I’m curious if this is now standard on current year Dutch Star and perhaps other models.
It is standard in 2021. This is mfg by KIB, and outputs to the kib sensor data same as strips. I just looked up parts on comnet. Very slick.
I read the description, the problem in my mind is it's not water nor a consistent density. I can see this used reliably on the gray side but I'm curious on the dark side.
I read the description, the problem in my mind is it's not water nor a consistent density. I can see this used would areliably on the gray side but I'm curious on the dark side.
You don't think milkshake slurry pressure will be the same as Grey water pressure?
A test would be necessary. My thought is initially the milkshake would have a lot of air in it, and be a bit more foamy. This would eventually settle, and the pressure would be applied against the sensor.
I don't think this would work with non-macerating toilets.
This thread will reach over 100 posts. Poo threads always do. :ROFLMAO:
I don't know how it works, but it DOES work and it works well so far. ?
