Breathing new live into my 2000 Dutch Star
You have to list the items you use as a lot of us have the same or similar fittings. Thanks
Here is what I have used on the dash.. So far.
I would opt for a 4k camera system over this one.
Be sure and order correct for your rig adapter for steering wheel
Not installed yet.
Thanks. Still working on the steering wheel. Have to get someone at spartan to talk to. Newmar couldn't answer.
If you want one of the "Forever Sharp" steering wheels, you need to talk to Forever Sharp for the correct adpater, not Spartan or Newmar.
Pretty sure this is the one you need, but would check with Forever Sharp just to be sure.
I just installed the chrome vents this week. Always thought the black ones looked cheap and ugly.
Thats how I felt about my coach model #. Overall its a very nice coach but the model number was just black tape type numbers. Looked cheap. So I peeled them off and gave it a nice chrome “3427” more befitting the quality of the coach.
Thanks will do.
Not installed yet.
I will be ordering a wireless 4 camera system for mine as the voyager system died. Haven't decided which one yet. It is kind of at the bottom of my list got 2 good mirrors and use the wife as a ground guide if needed. I'll take a picture of my head unit that I have 10" screen and you can project y our phone to it.
Very nice article on this restoration, keep up the good work and thanks 😊
So I have been putting up paintable wallpaper in the front of my coach. Got to the right front by the door and the was some wrinkling in the factory paper under the window. It was soft underneath the paper, so I knew there would be water damage. Pulled the paper back and this is what I found. Really looks worse than it is. Had very slight leak at bottom of window. The floor is not hurt. Looks like it may have been leaking since new to me. the seal they use around the window is all woppy jawed. And shrunk. Poor choice of material in my opinion. I will be reinstalling window using a high grade silicone sealer. Should last the rest of my lifetime.
I will be resealing all the other windows also.
Woppy jawed - a new one for me, sounds like something from W. Texas. I’ll have to remember that one! Yeah it looks bad at first glance, but its a small area and the exterior and floor arent involved, so I agree, not that big a job.
Here in so. IL we say whopper jawed.
Furnace worked last year, not this year though.
Removed it and started checking things out. All the switches were working.
Tore it apart to check the ignitor and gas jet.
Dirt daubers had completely buried both units.
Finished completely tearing it apart, clean everything out.
Heat exchanger had nest all through it. Took forever to clean that out.
Reassembled it and bench tested it. Works great.
No parts needed, just some labor.
Reinstall in MH and I have heat.:):)
With all the work that you have had to deal with, I hope that you bought this unit at the right price.
I've done this several times, with cars, Jeeps, RV's, houses, you name it! Sometimes it wasn't about money, it was because I enjoyed the transformation that was taking place and the product that I eventually ended up with. Most of it I enjoyed very much.
You forgot building an RV Park😳
