a bit wordy, as I wanted to provide some background. issue at the bottom.
so I came up on a free 2009 Forest Wind Tail Wind 12x6 cargo trailer, neighbor of a friend brought it to CA from TX, apparently in TX cargo trailers under 4K lbs used on farms are not required to be registered, as such this trailer was never registered or titled, so once in CA the DMV would not register it without the TX DMV paperwork, original bill of sale, or the manufacturer statement of origin.
This gentleman got 2 tickets for using it on public streets without tags, the second one was several hundred dollars, so he just wanted to get rid of it.
doing a bit of research with the CA DMV I discovered that a notarized bill of sale from a private party sale could be used to register and title the trailer, so I had my attorney create one, the gentleman signed it as selling the trailer to me for $1.00 and we got it notarized, done deal $36 later the trailer is titled and registered.
EXCEPT:
I also need to have a CHP inspection of the trailer and the lights do not work. So I have a temp operating permit for 30 days to fix this,.
I got under the trailer and discovered that the wiring is a mess, something must've chewed through it at some point as it is wire nutted (not even crimped) in several spots, and not wired correctly (i.e. to a standard 4-pin color pin out). right turn applies brake lights, left turn flashes right signal, brake flashed left, no tail lights at all.
so I ripped everything out, my truck has a 7 pin connector and I'm not a fan of 4-pin anyway, plus I think I want to add e-brakes to this trailer at some point, so I bought a full 7-pin harness on Amazon and re-wired everything and replaced all the 14 year old incandescent lights (marker, tail, turn, etc) with LEDs.
everything is working great except one thing. the 7-pin has a 12volt line for battery charging, I installed a motorcycle sealed AGM battery to power the interior lights of the trailer and a roof vent fan.
But I am not getting 12volts on that line. only 3volts.
Checking at my truck and I get a full 12 volts, checking at the junction box I get a full 12 volts, checking at the battery and I only get 3,
same harness and hookup for my travel trailer, and full 12 at the battery,
any ideas?
EXCEPT:
any ideas?
