Already did this.First thing to try: Salesman switch off for over 1 minute
Do you have a phone number by chance?You might try John brown at KIB for ideas.
Rick didn't mention one, but he is helping me to find a tech.@ARD How about a newmar mobile tech? Are you within 100 miles of one?
Thanks for recommending that I speak to KIB. I did not speak to John Brown as he is an engineer there and typically doesn't speak with customers; however, I did speak with Walt and he was fantastic.KIB main number 574-262-0518
Can this be fixed without having to go to Nappanee?I believe my command board is in the back closet, but I will have to check. In any case, it is getting the signal so the switches are not the issue. The problem is narrowed down to either the string of lights got disconnected and or went bad.
It looks like it. Newmar got hold of a mobile tech that they said can make the repair. I should hear from him today or tomorrow.Can this be fixed without having to go to Nappanee?
Don't know if this is the same issue, my lights flickered and 2 randomly turn on in the night, I read this thread and shut the salesman switch off for a couple minutes, so far all is good, no more flickerRenee I totally understand what you have been through, the frustration can be overwhelming and at times seems extremely personal. Only you know what’s right for you.
I believe you said that you tried the battery disconnect, did you leave the power off for a couple of minutes?
If not you can give that a try. If it still continues and it’s all of the lights in a zone, it sounds like a control board that is going out. One more thought, can you try and dim or un-dim the ceiling lights? I don’t believe it’s a ground issue if only one circuit is effected
Yes. I left it off for several minutes. I can dim and the indicator is red as I move it up and down as if it was working, but no ceiling lights.I believe you said that you tried the battery disconnect, did you leave the power off for a couple of minutes?
