Kevin D Pem
RVF 1K Club
- Jul 29, 2020
- AZ
- Alpinelite
- 26'
- 2016 Ram 1500
- Yes
Yes it would work. the power from the genny will run the converter giving you house power and the starter on the genny is supplied by a much larger wire.
In our minds we must isolate house from chassy systems. The only time they are connected is for charging the house battery while underway. because of this we must not confuse ourselves with the chassy system at all.
Any thing added to the coach that the wire from the battery is not fused most of the time within 3ft or before going through a wall was not installed professionally. Think of it this way: if a wire shorts and does not have a fuse the battery may explode. acid would be everywhere maybe even a fire would start. No there is a fuse someplace close to that house battery that would keep that from happening. To bad you are not around williams AZ I would say drive over to my camp and we would fix it.
