Vinni
- Oct 22, 2021
- So Cal
- winnebago
- Journey 36G
- Freightliner
- Catapillar 350
- 2010 Ram crew cab 3500 DRW Cummins or 8.5'X24' Enclosed ToyBox
1 ordered a new 2021 RockWood ultra lite 2882s with 190 watt solar/inverter option. This is what I received. One solar panel with Go power controller matched to a WFCO inverter. The factory chose to leave out cable from inverter to controller. The reason being that the controller is not compatible with WFCO inverter. This is because of interface problems. Mismatched components don’t function correctly together when they are combined in a system. Now the A/C button on controller will not function inverter unless you go out on your own and purchase on from Go Power and install it on your own. They said this is what you get. The inverter is “Ready Accessible “ in the exterior compartment that is located opposite traffic side with a button on inverter. We are not talking any responsibility for button not working or providing remote switch for inverter. They said I have to exit coach and go to traffic side compartment and turn off or on inverter as needed. That doesn’t seem right to me. Especially since I am unfortunately handicapped individual. Even without a personal problem I do believe this is a electrical engineering problem. What has been delivered is a MISMATCHED INCOMPATIBLE SYSTEM. This is due to Interfacing problems between components installed. Owners manual show functions of components And mine doesn’t function per owners manual. The inverter manual says there is a remote switch provided with 20’ cable. My coach doesn’t have one. The factory omitted these due to incompatibility issue. Forest River Owners with factory solar option are being ripped off Is you controller central doesn’t turn on and off inverter.if the system wasn’t mismatched components you would fully functional electrical system. Just what I would expect from factory Installed components. So we contacted Go Power who advise to have go power inverter installed with provided cable and all would function properly. Forest River replied go Power inverters are unreliable. Isn’t that a matter of opinion? If Go Power is “Unreliable “ why are they using Go Power Components? Forest River Claim Customer Satisfaction is important. It doesn’t appear so. So if you are buying Forest River product with Factory solar options BUYERS BEWARE!!! Your thoughts are Welcome. Thanks
