Thanks, Bob. My pet peeve is someone posts a problem and sometimes someone spends a lot of time and effort to help and then you never find out did it really help.Thanks for posting your solution. I wish others would do the same. It would make the forum more beneficial.
Problem resolved. I left the salesman switch off for over a minute and the slide now works.
When we had ours, it happened to us too. My normal startup procedure is:
1. Turn on Chassis Switch
2. Turn on House Salesman Switch.
3. Start main engine, let it stabilize.
4. Start Genset and enable inverter to run fridge when traveling down road.
On one trip I started Genset First, then main engine, got to campground and FWS would not deploy. Turned out, doing it backwards caused the slide relay to get wild hair up its chip. To resolve, called Newmar, tech had me turn off Salesman switch for minute, turned back on, slide worked fine. Try just turning off coach for minute, bet it works after that.
Happy Trails to all.
