MapNerd
RVF 1K Club
- Nov 17, 2019
- Prince William, VA
- Ventana 4326
- 2020 Ford F-150
- Yes
Glad you finally found the source of the problem. After all the back-and-forth on this thread, the obvious problem sources had been eliminated And there had to be some kind of internal blockage. Sounds like someone got overzealous with the glue during assembly. Stuff like this happens, and drives you crazy trying to find out why something doesn't work as it should.Back at the service center this week. Newmar took apart my grey tank drain all the way to the tank - it turned out to be a big glob of pipe glue that was clogging the tank drain. So that’s a new one.
Any pictures? I still find that hard to believe. It’s a 3 inch hole. Not small.Back at the service center this week. Newmar took apart my grey tank drain all the way to the tank - it turned out to be a big glob of pipe glue that was clogging the tank drain. So that’s a new one.
If a "big gob of pipe glue" oozed out on the bottom side of the fitting, it could collect debris that, over time, would form a dam. I can see how that could happen.Any pictures? I still find that hard to believe. It’s a 3 inch hole. Not small.
ValidIf a "big gob of pipe glue" oozed out on the bottom side of the fitting, it could collect debris that, over time, would form a dam. I can see how that could happen.
Tech has a picture. I will get a copy and share when I have it. Also its a 1.5" diameter on my grey drain. I think the switch to 3" on grey came in 2021.Any pictures? I still find that hard to believe. It’s a 3 inch hole. Not small.
I did. Tech seemed hesitant to say he would so I’m not hopeful. Such a simple thing...smhYou can ask them to run 3 inch out of gray, I would if they had it all apart. It's just the same plumbing as they use coming out of black.
