Help Dead Battery!
Also for further clarification and to correct my original post, we did not “come back to dead chassis batteries“ we came back to a perfectly working coach. Things did not go dark until a few minutes later when my wife turned on the air fryer While the convection oven was also running. Even so, I would expect that we would have burned a fuse or popped a breaker none of which seem to be the case.
We simply thought originally that we came back to dead house batteries because we didn’t associate the loss of 110 V power with the use of those appliances immediately as we only been in the coach for five minutes so we assumed
If the 12 volt coach lighting is working then I can't imagine it's the fuse, otherwise the power wouldn't be getting to the lights.
If the 110 side of things isn't working on shore power of generator, then it's going to be something between the 110 power sources(s) and the breaker panel. The inverter indeed is between there.
I understand you have help in route, but can you tell me if your inverter has to be turned on to pass shore power through to the coach? Some inverters pass power through regardless of whether on not the inverter is on/off. Some require that the inverter is turned on, or the shore power (or generator power) will not get to the interior of the coach.
Another quick question, if you don't mind. Are ALL of the 110 outlets in the coach dead? Or just the one that your wife was using when she plugged in the appliance? And can you tell me if the refrigerator is working please?
All outlets are dead. Refer is not working.
Not sure if the inverter needs to be powered on in order to pass power. Will check the manual to see if it says anything about that when I get back to the coach in an hour
Thank you MapNerd. I really don't see the transfer switch failing because of your wife overloading the panel. But that being said, if the main panel doesn't show any blown breakers, then I'd get suspicious of the inverter. Mine had a breaker built into it and when it snapped, I about never figured the problem out. Have you checked the inverter for such a breaker?
EDIT: The breaker you'll be looking for will be built into the inverter itself. So you're looking for a switch basically.
Try calling Sensata tech support, they make the inverter. I’ve spoken with them before, very friendly.
425-353-8833
On ours VT-3407 AEC. Generator will provide AC power to all places it needs it, regardless of inverter status. Hooked to SP, I actually have not checked that, but we leave inverter on when traveling so fridge and MW has power. Then the inverter passes through if hooked to SP, or genset running. Going to assume, that if hooked to SP, and inverter is off, AC devices will continue to operate, once AC gone, they would stop. FWIW-I use a portable surge protector on the pedestal even though we have one built into coach, just another level of protection, especially with it being All Electric unit. If we are only stopping for one night, I use the portable to check shore power pedestal, but then put it away and use the built in. Long stays, use the portable one locked down to pedestal. If, we have only got 30A shore power, I will use the portable one always, regardless of length of stay. 30A SP is hard to judge current use without looking at the panel up front and gauging the total amps being consumed. Several times the system initialized the inverter to meet needs even with SP working. On 30A SP, it seems to take longer to charge house batteries (8 of them). But that is just a feeling. Has this problem been fixed yet, don't seem to see resolution.
If you said 300amp fuse, you have won a chicken dinner. Picked one up today and replaced it just to see and voila.
Now, the question is "Why did the 300A fuse blow instead of a breaker tripping? When fuses blow (especially big ones), there is a reason and it would be well to find it. Just running a microwave and an air fryer at the same time should not be blowing a 300A fuse.
Glad you got it fixed. Hope it stays that way.
On the contrary. 300amps at 12VDC is not all that much when inverted.
120VAC at 28 Amps = 309 amps at 12 VDC
Quite easy to exceed 28 amps with those 2 appliances. Wait for shore power or generator for that much amperage.
Maybe this is the answer; my new replacement fuse!
Note the 3750A rating stamped on it! It came from a power company substation.
Hmmm, we have on occasion (at least one time-that I can remember) gotten up to around 49A incoming, however, that is with 50A service which all know is really two legs of 120VAC @ 50A per leg. 30A is only 120VAC @ 30A on ONE hot leg. However, it seems to me, that the inverter should have kicked in, to provide the additional current needed to power the two devices, my coach does and has done it lots of times when we were plugged into 30A shore power. We never blew fuse or even tripped breaker. We have induction cooktop, was using one side of that, electric oasis heat both sides, and maybe I started a heat pump to take chill off the rear area. Anyway, nothing blew. Suggest you might take the time to ensure all electrical connections on both chassis and house battery banks are tight. I did that first after getting coach home from purchase. None were lose, but some were not as tight as I wanted, smeared NO-OX-ID-Special A all over them to keep corrosion down. And although situation has been remedied, still think it should not have happened, through inverter it should have been able to handle at least 60A and some of the total load was handled by the 30A SP. Since all receptacles are 15A max, except the microwave is a 20A dedicated circuit. If I remember correctly, mine (cooked chicken on convection) was using about 18A, the cooktop (substitute the air fryer) would use another maybe 13A, 31 total, the inverter should have kicked in. The fuse which blew, was on the DC side of the house, and as such would not have been carrying the complete load of the coach, because the 30A shore power would allow the inverter to "pass through) until it reached 30A and then kicking in providing the other amps needed, no where near the max as shown in another post. So something is not kosher in Denmark based on the explanation so far and the solutions outlined so far. Or, I am completely missing the facts. My guess is, the fuse was not a good manufacturer and/or had some corrosion internal which caused it to fail. Don't think they have date codes, but twas me, if they do, I would make sure I had one with a real current manufacturer date. I have only heard this happening less than 10 times, so this is a rare occurrence.
Well great! Glad it was an easy fix.
I can’t really contribute to this thread, but I have read it with interest, just in case...I’m happy you solved the problem...I would still be interested in the root cause of the problem, though.
Just remember the induction cooktop outlet is not fed by the inverter and should be used for high amp cooking appliances. It is on the shore power side.
