Old-RV'er
RVF Expert
- Feb 23, 2020
- Blairsville, GA
- Ventana 3407
- 34'10"
- 2013 Jeep Wrangler Sahara Unlimited
Ok, my best service experience in the west has been in two places. Believe you are near NW, so call Cummins coach care in Coburg, OR, and ask to speak with the service manager. Explain (assume you will be able to talk to him/her) and see if they can offer any insight. I have had my best success at that facility. Realizing spartan built chassis, and then installed engine transmission, et-al. The ECM, hopefully is in about the same location as FL. My fallback would then be the Freightliner dealer in Tolleson, AZ. I have no experience with spartan, must be some good ones, and maybe you have one in mind. Got to be someone, who cares enough to help you. We all do here, not much we can accomplish here though.
Ok, not germane but might be. Stored my jeep for month outside and when came back to get it, over next few weeks, just did not work correctly. Found out, mice had gotten into wiring harness under a cover in engine compartment, ate some insulation on wires (now built with soy based products) and the fix was a 1200 wiring harness, or the tech spliced them all back together individually, regardless 460.00 later car has run fine for last 5+ years after that experience. So my suggestion is to look around all over the place and see if mice have fed on some of your wires, realize this is a long shot, and even if reason, you might not see damage. I now keep mouse traps all over MH and Bounce dryer sheets in compartments, got the best smelling storage compartments around, and no mice. Yes, could be relay going bad, or fuel shutoff solenoid, but those should be covered under warranty. Let us know., as short of that, out of ideas. If your experience with Spartan, Cummins, and Newmar. We have our last RV period.
