TJ&LadyDi
RVF "Dinosaur"
I received the new ignition switch for the 2018 Mountain Aire from Spartan today and am hoping it will solve the engine shut-off problem discussed in a previous thread. I plan to install it myself and could use some advice.
Examining the new switch, I can see that it connects to the electrical system via a single, six-pin insulated square plug. Simple enough. The biggest issue will be accessing it. There appears to be a small, removable panel (4 screws) at the bottom of the dash that looks to be in the right position to gain limited access to the back of the switch. Hopefully, I can unscrew the bezel and pull the old switch down to swap in the new one. Has anyone changed out one of these switches? Is the panel I’m seeing likely to be for that purpose.
I am thinking that I should disconnect both the house and chassis batteries (via the appropriate disconnect switches) prior to making the electrical swap. Given the insulated, modular plug connection, that may not be necessary but I’d prefer to be safe rather than sorry. Is there any issue with both sets of batteries being disconnected at the same time for a period of time; probably 15-30 minutes? I’m wondering about things like system computers losing losing settings/parameters, etc. Any thoughts?
Any other advice would also be gratefully received. Many thanks.
