- Jan 19, 2021
- Ventana 3427
- Freightliner XCR
- 6.7 ISB 360/800
- 2001 Jeep Wrangler
I add water to my batteries more or less monthly unless I’m not plugged in and using solar a lot which causes more charge cycles in which case I check them more often. Anyway Im home how so I’m plugged in which miminizes house battery use so reduces the need, so….monthly.
So I did the usual with my hand bulb pump adding water to the six house batteries through my watering system from a gallon jug of distilled. As always I pumped until they wouldn't take any more, then put everything away. But I also noticed some corrosion on some of the connections so I decided it was time for a little battery maintenance.
But when I pulled out the tray I could hear water running down inside the batteries. Finding this a bit curious, I got out the pump and tried adding more water. They took about another 1.5 pints! So my little discovery is that something (air pockets?) is preventing the batteries from fully filling when I go through my normal routine, and it seems the batteries need a little agitation to cause the water to settle in all the way allowing me to fully fill them.
Or am I now over-filling them? Seems odd that the water would remain in the top portion of the batteries with a void below that point and not allow the addition of more water. Ideas?
