Jim
- Dec 18, 2019
- North Carolina
- London Aire 4551
- Freightliner
- Cummins / I6 Diesel Pusher 600HP / 1,950 ft-lbs
- 2016 Jeep Rubicon
I just wrapped some black tape around each nipple. But to be honest, I don't see any reason to cover it anyway. It's just a coil that you'll never use again anyway. I mean, the DEF header is broken, you're not going to fix it unless you replace it, so I can't really see any reason to worry about plugging the ends.I appreciate the comments from Jim and Jerry!
Based on what you and Jerry said, I'll be joining both lines together. What did you use to plug the elbows going into the tank? Any other tips appreciated.
EDIT: I don't know if you read this or not, but here is the page where I did exactly what your are getting ready to do.
