TXbound
RVF VIP
- Jan 6, 2021
- Winnebago
- Adventurer
- Chevy P30
- 454 Vortac
- Yes
The Winneabago Adventurer we have has 3 large after market Siemens panels and one small one, what loooks like came factory installed, the installed Mark PV Controller, showed Array Current at 0, I tested for current at the panels themselves and I was getting around 17 or so, I'm not sure I think they are wired in Paralel, when I was in Quartzite, I took out the controller and disconnected it and examined it, the AGC fuse for the array was not only bad, the holder was partially melted. I spoke to some folks there at the swap meet and they told me it might be the controller had a cheapy controller for $50 that may or may not work since it was a demo so I stopped by the Solar Discount place there in Quartzite and the salesman told me that before I replace the controller, that I need to determine the wattage of the panels and that most likely they are 30 amp, so far I have not been able to determine the wattage, I tried to use a inspection mirror to see if I can look under but can't see, taking one out looks to be more trouble than it's worth I can only assume each panel is at least 100 watts. I recently went to Harbor Frieght and picked up a low cost Thunderbolt 500 watt solar 30 amp charge controller, but I'm concerned about wiring it to the setup since there might be an underlying issue that caused the fuse to melt, upon examing the Thunderbolt and checking the instructions there doesn't seem to be any kind of fuse to protect it like the Mark PV has, so I would think it would be recommended to have a inline fuse at the battery, actually that was suggested to me and I do have a 25 watt inline that I can wired to the batter,y, I take it that would be to the hotwire negative side. I've considered gettng some help from a pro,. but if it's something I can D.I.Y. I'm willing to give it a go. Any thoughts?
