JRS
RVF VIP
- Jan 25, 2020
- Full timers
- Dutch Star 4328 - FL Chassis
- 2018 Jeep Grand Cherokee
- Yes
Highly recommend not getting the shower seats installed.
Our shower seat failed. The chrome circular plastic mount covers actually split. We really never used it as I sat on it like once....We ordered a new one from Newmar for $400 plus (they don't sell parts) just the entire unit. Today i worked on taking the old unit off. IMHO a poor design.... What occurred is the soap ended up accumulating in the chrome plastic mount covers to the point where eventually it swelled enough to crack them when they received water to split them. Pretty gross. They were filled with dry soap. Prior to taking them apart, I guessed it was rust that split them.... No rust at all...
After taking quite some time having to use vice grips to take the rods out (by cutting sections of the plastic covers) to remove the seat, the phillips head screw on the low side of the mount stripped. When the lower screw head stripped, I cut off the plastic mount to gain access to the 3 upper screws holding both mounts. All 6 upper screws sheared off... Then, I had to drill out the lower screw heads on both mounts to remove the mount. There was enough of the head to use the vise grips to shear off the lower screws. They used some kind of glue to hold the mount to the shower mall and had to use vise grips to leverage them off.
So in order to reinstall the seat, the mount will have to be moved to drill new holes. Both the DW and I think it looks so much better w/o the unused seat. So tomorrow I'll head out finding a material to fill in the 8 approximately 3/16" holes.
On the bright side, no interior damage to the wall....
We'll keep the seat and I'll install it when it comes time to sell the unit.
A friend just purchased a new 2022 Allegro Bus and his shower has the same seat....
One last note... we full time so the shower is used often.
