Newmar not taking accountability? Passing the blame on quality to vendors?
Stuart, I totally agree. I was in the car business for 44 year and with the exception of the last 15 years I was on the service managment side. As a ASE certified master tech and former field service engineer for GM I know just about enough enough to be dangerous on my coach. LOL. I bought my coach new from NIRVC in Vegas, and yes they are not perfect, but when there has been a problem they have always steped up to resolve. I have to say, RV dealers are faced with a huge staffing challenge but I think that is where NIRVC stands out in the effort to make it right when something is wrong.
Scott I see that you have a 2019 Newmar, in my opinion that was the last of the true Miller Newmar’s. It was a different time, sure the Miller’s cared about making money, but it was also their personal reputations on the line, they surrounded themselves with employees that were like family. You may notice that almost all of those employees are gone now.
Having owned a 19 and a 21 Newmar with basically no issues. I do not believe there is a difference in quality between a 2015 newmar and a 2020 and up.
Having owned eight rvs I rarely had too serious an issue myself. That could be because I try to fix or do preventative maintenance and I accept that they are rolling earthquakes and stuff will happen.
If you truly read most of the issues the last few years, most can be attributed to operator error. I see complaints about the simplest things. Literally one person complained because they had no idea how to tighten a tp holder, a residential one, and four responders said, Newmar quality has gone down, really! I think the majority of buyers years ago were more of a hands on type. Also, remember today we have a multitude of forums, facebook and other groups. Back then we did not. Nowadays I notice people cross post the same question on a few forums and a few fb pages. Those actions seem to falsely multiply the idea of numerous problems.
Then when they post, they get a large number of answers that are blatantly wrong. Which adds to the mystique that there are a major number of issues. And the fact that many owners a not handy.
How many times have you had an issue only to find out you were not operating it correctly? It happens, we are all guilty of this to some degree.
Are there issues, yes but I do not believe there are any more then ten years ago, its just now that there are more places to post, hence more places to see the same complaint with different poster names.
A few of the examples of how design and build vs tossing suppliers under the bus is perhaps the real story...
Since purchasing my 2023 Newmar New Aire I have had 4 of my automatic day shades "forget" their limits in less than a year. Should they? Probably not, but I wouldn't mind if there was access provided to adjust their limit screws. Sure Newmar provides the plastic tool for making adjustments in a drawer, but when you mount the shades, adjust them, and THEN build the cabinetry around them blocking access to the adjustment screws... Ugh! Now, instead of making the adjustments myself I have to schedule time with the dealer's service department to burn warranty hours and $ for something that should have been easily solved by mounting the shades at the correct angle (with the adjustment screws facing downwards vs sideways) or with removable inside interior cabinet wall panels for access.
Another example? Don't install the absolute cheapest solar controller possible that only handles lead acid and nicad batteries and then factory option Lithium batteries. Of course that bargain basement solar controller isn't going to charge those batteries. But this went on for well over a year of rigs going out the door. Now Newmar is eating the cost of the service bulletin and replacements on how many rigs?
Ceiling vent panels falling because the magnets in the wooden frame come unglued and out of the pocket holes drilled for them? Use magnets that screw into the wooden panels instead...
Tile grout cracking within months of purchase?
Nav constantly losing GPS signal?
Docking lights wiring shorting out due to side body panel pinching the wires as it was being installed?
Silerleaf not able to update WiFi connection due to old beta firmware being loaded vs latest released software version?
Don't get me wrong, I love my New Aire, but in my rig's case these all seem to point to gaps during fabrication vs the individual vendor parts. The Dometic Toilet no water during flush switch issue is the only one I can think of that was on the supplier...
Best,
-Mark
The mention of navigation brings up a sore spot with me.
When my ‘21 was built, the RM nav system was installed. Somewhere about the time I showed up for FPU, it was announced that RM was ejecting the RV business. Did Newmar and Riverpark know that was coming? They had to, but they kept installing it anyway.
That still fries my bacon every time I think about it.
Maybe I should quit thinking about it.
Let me chime in here, after working with Newmar on CPU, and NIRVC service in Atlanta, these are very complicated machines and Service does vary by tech.
Newmar has always stepped up when I’ve had an issue. Yes it takes time and perseverance to get some things done but they get done.
For instance, I had a BIRD issue. Went to Tampa RV Show because I knew my Service Team from Nappanee would be there, Jonas and Perry.
They fixed the BIRD issue and John from KIB was there to verify the BIRD programming and other KIB systems were programmed correctly. Covered by warranty.
Typically I go to Nappanee for service and know the quality of the work.
Found that most dealers need several visits/trips to get whatever service correct. And most ask you to leave the RV. Typically not something I do willingly.
NIRVC, Atlanta allows you to camp on site currently. However the place is extremely busy and can be costly.
Managing logistics there is very difficult. Some “Campers” had been at dealership for weeks. And NIRVC has 200 RVs parked waiting for service.
The new President of Newmar is working with Customers face to face at Rallys to determine problems. He is also demanding senior management to use the product and know the customer first hand. Hopeful signs.
Has the time of Private/Family Ownership of RV mfg passed, maybe. And the Class A market is in decline now. I expect the Class A mfg pool will shrink.
The commercial end, Prevost, will continue for a while with custom coaches. Low volume, high dollar units will be in demand for customers who want a coach for business traveling and those that want custom equipment.
Unfortunately it is not Miller Time at Newmar any longer.
I think they intentionally buy outdated clearance items. Case in point the Clarion dash radio in my 2017 Ventana. That radio was 10 years old and long past something sold to the public. Shall we talk headlights? The dash air controls are ancient GM style tech. Flexsteel and upholstery choices? Whirlpool washers were high failure. It’s a string of poor decisions and allowing these people to make these decisions. At the recent Hoots when asked about headlights and some Newmar exec mentioned Sylvania Ultrabright bulbs as some earth shattering breakthrough, many of us gasped. Someone better get decision makers at Newmar into 2924
Casey Tubmen, President of Newmar, groaned when I brought up headlights at the Keys rally. He has heard that compliant multiple times at every Rally he and wife have attended. :)
Hopefully now that more OEM vehicle manufacturers have obtained DOT approval, RVs might get LEDs. RVs MFG just don't have the volume to be able to amortize the cost of DOT lightbulb approval.
The led bulbs in our DS are very popular, thank you Neal, and sold as Off Road only due to lack of DOT approval. OEMs cannot install these in New units.
Uh, the Navi thing. Not to change the thread subject but last year I ordered the Nav n Go card from Riverpark and convert the RM over and what garbage. It like using a 1980's DOS computer, is clunky, slow and overall I felt like I wasted $250.00
Headlights!!! There is many trees you can climb on that topic. Will make a new thread to address it!!!
Isn’t it ironic that a ex Whirlpool executive a company notorious for making the worst RV washer dryer in the industry, that even Newmar had to stop using, is now running Newmar🤔
Nothing like finding out that your brand new Newmar has a 3 year old map installed, I calle Newmar and was told that I could purchase a map update online
Sounds like a clearance sale with a sign that reads "no returns on clearance items"
Seeing all the issues with the newer units, I'm happy to stick with my "old school" 2016. :cool:
We feel the same way with our 17. Love the coach
