- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
@Jim there is logic in the systems that at a certain temp somewhere 40 or below they will auto switch to furnace. Mine does it at 32 which is too low but I verified it works.
Changing the pumps in your coach would not be hard as you have big basements. The pump location is accessed from the passenger side and you'll likely have to remove one of the wooden "faux" walls on the back side of OASIS or shore power reel, I can't remember which, for me it was the bay forward of the pegboard.
You'll need something to clamp off the hose(s) to avoid fluid loss. I use these (get 2):
ITR Heat is great to talk to if you need troubleshooting advice. I've done far too much triage in mine from electrical shorts, failed pump (so far only 1) and then of course the annual service kits which if you don't know if yours has been done I recommend picking up a 5 year kit.
Itrheat
Phone: 800-993-4402
5 year service kit (other options are 1 and 3 year kits which have reduced parts for service):
YouTube has videos on performing OASIS services.
Carry a spare pump at all times, they can't be trusted! They went to a newer version which supposedly is better. I got mine from ITR but others found replacements which sound good but I have yet to need.
You can download the Oasis troubleshooting manual:
Have spade connectors and spare fuses on hand as well.
If you need more Century Transfer Fluid which your reservoir should be in the chassis battery bay (rear passenger side) make sure you put the same kind in that you have already but it should be this:
I understand, but they would probably be whole lot better than the one (1) working hydronic zone.They are not very effective below 40 but should work.
Yes, indeed. But how does one manage this? I can turn the Oasis off, but how do I turn the heat pumps on?The rule of thumb for manually managing this is to use heat pumps when the outside air temp is above 40F.
Haven't been able to find that elusive little bugger as yet.There should be an option in your climate control to select heat pump vs. furnace.
Well alright! We're cooking with gas (electricity) now! Hardly straight forward though. Thank you, Neal.![]()
Answered - Using Oasis instead of heat pump?
Just out of curiosity, I'm wondering if it is possible to use Oasis for heat instead of the heat pumps? I know that Oasis will switch in when the outside temperature drops to 40 degrees or so, but is there a way to manually enable Oasis at other times? On our MADP, the climate control is...rvforums.com
Thanks Rich! It's simple now that I understand the terminology and where the settings are. But last night, well not so much!On your other heat sources, you have heat pumps, not just air conditioners, so you need to find that selection on your thermostat. Mine is simple, but yours may not be.
Hey Rich, were exactly are these fuses?If you change the fuse and it immediately pops the new one, you have a bad (stuck) pump.
