Oasis Zone Fault
This will be my next pump substitution. Ive used the 3/4” retro kit when the correct ITR pumps were unavailable (total pain and will never do it again) and most recently replaced the summer loop pump with a current ITR item ($300 so that‘s beyond reasonable), so I’ll order one of these soon just to have it in stock. I don’t have experience with them yet but got this source from someone who had good results. The price is right and it has the right specs.
I can tell you from experience that anything with other than a 1/2” barbed fittin (or 12-13mm) isn’t worth the effort of retro-fitting. There is no extra room in the box for messing around with adapting hoses.
As for the $300 ITR pump, they seem to indicate that it is an improvement (don’t recall where I read that) over the original which for the price it should be. And the high failure rate is also really inexcusable. My unit is on its fourth replacement - every pump and zone one twice! Hopefully my new $300 summer loop pump will go the distance, but in the future I’ll use the $81 US Solar unit and take my chances.
I installed one of the solar pumps and it is a 100% perfect replacement.
Good to know - It may have been one of your posts that led me to it.
No heat in rear bedroom or rear bathroom. Oasis says zone fault for those areas. To late to go check for fuses so I'll do it tomorrow. But from what I'm reading, the fuses generally blow because the pump is shorted out or bound up. And from what I'm reading, changing the pumps is a real pita?
May seem like a silly question, but is the Oasis the only source of heat in these coaches? No heat pump?
Yep - its most likely a pump. If you change the fuse and it immediately pops the new one, you have a bad (stuck) pump. I bench tested a bad one, disassembled and reassembled it, and got it to run and then it started smoking and burned up. So just replace it.
You can pay $295 for an OE pump, or try the US solar replacement pump (mentioned above) for a little under $81 - well worth trying a new one and it has @Buly’s endorsement. Thats what I’m going to do next time.
I’ve replaced all three of mine (one of them twice) so I should be good for a while. It’s not easy and its not exactly difficult - just kind of a pain getting in there, clamping the coolant lines, cutting off the factory clamps, etc.
One thing I definitely reccomend avoidnig is the retro-fit kit with 3/4” fittings. It’s cheaper, and availability is better, but it is not worth the hassle of making it fit. I did it because there was nothing else available from Oasis/ITR/Hydronic warehouse at the time, and I didn't know about the US Solar pumps. But it was a shoehorn fit and not fun at all - never again!
Factory pump:
US Solar pump:
What not to get:
On your other heat sources, you have heat pumps, not just air conditioners, so you need to find that selection on your thermostat. Mine is simple, but yours may not be. So when plugged in or on the genny you will generally use your heat pumps; when “unplugged” you’ll use the Oasis. You may very well have heated floors too. You really need your MSRP and build sheets, available from Newmar - they’ll email them to you.
There should be a heat pump in your hvac unit handled by the thermostat. At least that was how it was in my Ventana. LADP might be different. On the oasis pump, it’s typically the summer loop pump that was problematic. I’d go turn the oasis on and off on the driver side bay and see if that makes a difference.
One other thing I seem to recall there was a switch near the dash that had to be turned on to get the furnace turned on tied into the oasis. It’s been a while but that what I remember.
Just looked at the brochure and you have the same thermostat I have. So just hit the mode button for each zone until you get to Heat Pump and set your temp. There is a short delay but it will come on and start blowing heat in a couple minutes and they really put out nice heat.
From the 2016 LA brochure: F6F7A96C-8EC0-482A-9552-5161CEAE8E4F.jpeg
Mine looks like this with the heat pumps selected:
From the 2016 LA brochure:View attachment 15690
I have a silverleaf and unless the "mode" is hidden somewhere, I'm not seeing it. And for some reason the heat pump isn't coming on. Maybe because it's below 40*?
They are not very effective below 40 but should work. I recommend getting some heater hose so you can replace, I imagine yours is probably hard/stiff due to age. I measured and put on hose on new pump prior to disconnecting the old pump and hose. I also recommend a pair of hose clamps and lots of rags.
I also recommend the US Solar pump @Rich W. suggested, it is identical except you need to put on the electrical connectors.
@Jim there is logic in the systems that at a certain temp somewhere 40 or below they will auto switch to furnace. Mine does it at 32 which is too low but I verified it works.
Changing the pumps in your coach would not be hard as you have big basements. The pump location is accessed from the passenger side and you'll likely have to remove one of the wooden "faux" walls on the back side of OASIS or shore power reel, I can't remember which, for me it was the bay forward of the pegboard.
You'll need something to clamp off the hose(s) to avoid fluid loss. I use these (get 2):
ITR Heat is great to talk to if you need troubleshooting advice. I've done far too much triage in mine from electrical shorts, failed pump (so far only 1) and then of course the annual service kits which if you don't know if yours has been done I recommend picking up a 5 year kit.
Itrheat
Phone: 800-993-4402
5 year service kit (other options are 1 and 3 year kits which have reduced parts for service):
YouTube has videos on performing OASIS services.
Carry a spare pump at all times, they can't be trusted! They went to a newer version which supposedly is better. I got mine from ITR but others found replacements which sound good but I have yet to need.
You can download the Oasis troubleshooting manual:
Have spade connectors and spare fuses on hand as well.
If you need more Century Transfer Fluid which your reservoir should be in the chassis battery bay (rear passenger side) make sure you put the same kind in that you have already but it should be this:
New to the Oasis world but since the majority of noted failures are pumps, I ordered one of the Solar C1E 12V 20L pumps for my parts box.
The easy answer to avoid the need to quickly replace a failed pump is to not join Neal on one of his winter wonderland RV tours.
Instead, follow the birds south, then you can take your time to replace a pump.
Knocking on wood here… Oasis is now 8 years old and no pump issues. I check coolant levels regularly, and a couple times a year have to transfer a little back from the overflow to the main unit. Makes me wonder if pumps go bad due to having air in the system. Knocking on wood again…
Following this thread, though I am not a Newmar owner. Hoping you Newmar owners won’t mind a Renegade owner hanging around as our coach has an Oasis unit (instead of Renegade’s usual choice of AquaHot).
