J&JD
- Nov 3, 2019
- Fremont, California
- Dutch Star 4018
- 40’
- Freightliner
- Cummins ISL450
- Jeep Wrangler Sahara
This morning, the first day of a month long adventure, the DW stepped out of the shower very unhappy with the water pressure. While trying the valve I noticed that there was good pressure on the hot side and almost no water coming out when turned to the cold side. When trying to mix the two the flow was anemic. Knowing that the trip would not be enjoyable with the shower in this condition I reluctantly took off the valve cover to see if I could fix the problem.
Behind the two set screws there are spring loaded rubber tipped flow regulators. The cold water one was frozen in the extended position limiting the flow. A little bit of lubricant and cleaning got everything loosened up and full water flow back to normal. I decided to post this after reading about this being a fairly often occurrence that often was hard to diagnose. This is on a 2017 Dutch Star with about 50k miles.
