Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Since I know you got a huge discount, how much of the discount are you going to pass along to your best friends...buddy? Or, did you buy them on Amazon?Come and get it...now that my 14 pumps are on order, they are back in stock! US Solar - go!
I bought from the link below. I'll throw in a free pump if you help me install toppersSince I know you got a huge discount, how much of the discount are you going to pass along to your best friends...buddy? Or, did you buy them on Amazon?
off topic a bit, but what’s going on with your toppers?I bought from the link below. I'll throw in a free pump if you help me install toppers
C1E Circulating Pump | US Solar Pumps 2026
C1E Circulating Pump is part of our C series micro centrifugal pumps. It is a 12 volt 20 litre pump. It is designed to be quiet, compact and lightweight.www.ussolarpumps.com
From page 11 of the ITR troubleshooting manual:
Domestic Hot Water
The call for domestic Hot water is automatic. There is a temperature sensor mounted on the domestic water inlet pipe to the heat exchanger. Once the hot water tap is opened, the domestic water will begin circulating through this heat exchanger. Once the inlet pipe cools below a pre determined temperature range, the distribution module zone board will respond to a call for domestic hot water, as long as it detects that heat is available inside of the Oasis Heating Module. In this situation, the distribution module zone board will turn on the summer pump and will circulate hot coolant through a small loop (summer loop) that goes through the heat exchanger and back to the Oasis. This will allow a constant supply of hot water, whenever the domestic hot water is used.
if I read this correctly, the zone board turns on the summer loop pump only when the domestic water supply temp drops a certain amount thus giving a constant supply of hot water when called for. It does NOT run continuously.
Perhaps you are right, I don't know. Confusing at best!@Jim not sure I am in agreement with your diagnosis that summer loop pump is working. When you place in bypass you are now using one of the other pumps (not sure which one) to circulate the fluid therefore getting hot water.
Also I have had summer loop pump be intermittent ( no hot water) and not trigger a blown fuse.
You can take off the panel to expose distribution and verify pump operation fairly easily.
I had the summer loop (your right, stupid name) replaced at Newmar about 6 months ago. And while I have no problem replacing the 3 pumps, I don't see the reasoning behind it if the pumps are not the problem.The best one to answer that is going to be ITR but I've become all too familiar with this contraption due to issues. If I were you I would replace all three pumps and just new them all up. Get a 5 year service kit and new all that up. Then go from there. You don't know the history of the care of your OASIS I don't believe so this may just save you grief later. If you're attending a rally that ITR is participating in then they may be able to do all of this for you but it's not that hard. The link for the US solar pump vendor is probably in this thread and definitely on this site, order 4-5 pumps if you're going to replace 3.
In two hours you can be done with the above, maybe three. Then we can start looking at other items such as electricity, relays, etc. which I hope are not an issue but not hard to replace either, I had one that was bad, simple bad connector. Cheap and easy but highly doubt you have that problem.
Zone 1 and 2 are furnace/heat providers
Summer loop is hot water (pump with a stupid name)
I'm thinking of having a BBQ today. Why don't you drop by for a burger a little later?Well, my first question based on your luck with Newmar etc is "was it really replaced?" and also did they use the old style pump which has known issues with reliability or the newer style (new style is smooth and no cooling fins).
You could crawl in and open the panel to view the pumps, won't hurt to do that and see if you can hear or feel them working and also get a picture and share here if desired and we can tell you if old or new style pumps.
lol, have you seen that guy? He's so tall, part of him would be hanging out each side of the coach!I know someone not far from you, well, maybe in the same state and runs a mobile RV tech operation for private clients, cough, @NWIP![]()
