Buly
RVF 1K Club
- Nov 3, 2019
- TGO Titusville FL
- InTech
- In-Tech Dusk travel trailer
- Aluminum
- Lexus GX460
I don't know the scientific/exact answer but my guess is not much. I think this is connected via phased array radar.I was wandering how much the reception will be affected, if the dishy antenna on a tall pole moves during high winds. There must be some wobble. Don’t know if the antenna locks on one satellite at the time, or group of them?
I found RV mode to give you really unstable speeds over time as you're basically getting the leftover after the "local" traffic.I haven't seen the best of Starlink connectivity here in Granby, CO and I'm not sure why. Today I decided to check the Starlink app and it still showed obstructions which was from the last time I used it in Fort Collins (yes, there was a tree). I tapped "Visibility" in the app and it did a scan for obstructions which took 24 minutes (as the app showed). After that completed I'm now seeing good speeds. I wonder if there is a bug in the system that remember it's degraded or something? Here is my speed test after the scan. I'll see if this changes much over time but I'll be using this as AT&T is not consistent here.
EDIT: Still unstable on speeds here. Not sure why, clear skies, no obstructions![]()
So I did one better. I put my dish on top of my wrangler in a wooded campground to get better signal. You already know where this is going don't you. Someone came and talked to me as I was prepping my site to go out in town for a bit. Forgot to remove it from the roof. As I drive away the spare cord stretches out and boom the dish foot drags across my hard top and the dish crashes to the ground. The back cover pops off and the foot (made out of cheap cast metal) breaks a leg clear off.If you drop your dish and find out how fragile it is, as I did, it's $250 for a refurb, $599 for a new dish. Fortunately mine still works. I'll consider a new dish when an upgraded version comes out. Support was timely in answering my question on cost for a new dish.
