Richpatty
- Nov 2, 2019
- Wesley Chapel, NC
- Ventana 4310
- Freightliner
- 400hp
- 2007 CR-V
Ah Ha, thank you. This really helps bring down my prior anxiety level. I printed both pictures. I also see that you had to remove the factory female termination connectors and replace with eyelets. That's probably not what they're called but you get it.Good eye…. I forgot about that. The original wire was too short to reach the new location, so I spaced a black wire on to make it longer….
Perfect Rich, thanks. That is what I'll follow. I noticed that on my RV control panel above passenger seat next to coach door, there is a small sticker that says solar prep. I recently measured for my array on the roof and found the metal piece, behind where Neal explained he fished out his wires. Is there anything behind that solar prep sticker? And, where do I locate the other end of those wires behind the metal cover on the roof? I apologize if this has been posted elsewhere before.When I did my solar install, I did all of the basement work first, including wiring the controller to the batteries. That way, when I hooked up the panels, I could watch for the power from the panels appear on the controller, which in my case (Victron) I could see via Bluetooth. I also did the combiner box on the roof before the panels so I knew how long to cut the wires to the panels…
Yup. I have one as well. Remind me…. What solar controller are you using?Thanks. Jack at A.M.Solar said they're selling me a Smart Shunt which will allow me to monitor my system via my smart phone.
I've received several emails from FedEx about items drop shipped from various suppliers all ordered by A.M.Solar. Very likely the charge controller will be included in one of the boxes arriving tomorrow. I just watched a video by Garret at A.M.Solar regarding sizing the correct charge controller. The equation says solar array watts X .9 / 12V = amp output current. Since I will have a 1200Watt array x .9 / 12V I get 90 amp output current. The charge controller Jack at A.MSolar recommended is the 150 | 85. Garret said this difference won't hurt the controller, I just won't be getting the benefit of the additional amp current. At least that's how I understood it. The YouTube link.Is that the one coming tomorrow?
Ha. Yup. Patty is my wife.Thanks Rich I am assuming I can call Richpatty Rich.
You well known in the industry (electronics), that it's best to oversize your electronic components. Just remember that salesmen are salesmen. The engineers that designed the unit stated what were safe limits for reliability.I have not received it yet. Jack at A.M.Solar sized my system based upon what model coach I have and what I told him I was probably going to need especially that I was not going to be using my A/C when relying on solar power. It is a Victron 150 | 85. There will be six 200W 24V panels charging two LifeBlue 200Ah batteries. I'm trusting in his expertise. I think I'd feel better if I had requested a 150 | 100 but I'm deferring to his experience. I guess I could always add a smaller controller later.
