Jim
- Dec 18, 2019
- North Carolina
- Essex 4543
- Spartan
- Cummins / I6 Diesel Pusher 605HP
- 2016 Jeep Rubicon
And Jim’s as well!Richpatty’s experience
Great points—thanks. I may just remove the hub caps myself and reinstall them as well.Leslie,
Make sure the tire shop have the special wrench for the rear hub caps, or they will use a large pipe wrench and ruin them.
Also many tire technicians don’t know that the two of the hub cap nuts are reverse thread. All of the above happened to me when I replaced my tires.
I let them use my wrench, and instructed them how to remove the caps.
Where is that jeanie that comes out to grant your wish when you rub the bottle.There is a Jeanie at the campground Istay at every year, but she never shows up when I rub the bottle. Worse yet, she has never granted me a wish. What is this world coming to?Just checked the FMCA for pricing. I need 2 - 365/70 R22.5 and 6 - 315/80 R22.5 (Michelin)
Looks to be about $9,100 before install and extras.
The tires that came on my coach had issues. FL in Gaffney spent a lot of time on them checking runout or whatever it's called, spin balancing, in the end two were warranty replaced and my ride much smoother.
I will ask that the new ones are spin balanced and I'm also getting centramatics installed with them in November.
GoFundNeal launching in October as November's visit to Newmar ahead of FL Gaffney is also going to be an expensive one. And house batteries are coming soon, not sure when, but that's not far off.
Oh no. They put beads in my tire when I had a steer tire replaced. So far no problems.Regrading other types of dynamic wheel balancer methods. We tried the media you pour into the tire prior to mounting tire. It was a disaster.
Stuff clumped up and threw tire way out of balance in damp or cold weather. Just a PIA. Two different types of media before we went with Centramatics.
I ended up using RVtires.com also. Better price than RMCA for the Continental's I ended up buying. RVtires.com found a local company that I liked and used to install the tires.I joined FMCA for tires which do have good discount tire prices however I ended up going with RVtires.com better prices same tires available and they have a mobile mount service and come right to your location. That was two years ago and I have been very happy with the tires and the work provided. Tires were mounted by Pomps Tires Service. We were able to stop on our first trip at a Pomps for no fee get wheels retorqued/ check as required for the aluminum wheel.
Agree, If you have a blowout, you will most likely need a new rim anyway, let the mobile service get you off the highway and get things fixed upBut if you have a blowout you don't have any real options but to call a truck tire service company to at least get you to a service center so they are going to have to touch the rim and the tire unless you are going to have it towed and taken on a low boy trailer.
