- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
@MapNerd I was impressed with them. I was not a believer a year prior and didn't get them when I knew I was going north into frozen AZ. I'm really glad I had them, in fact they were required for the drive, which of course I wished I had known about and wouldn't have driven that pass or that day. But I had no slippage, they are effective. I only installed them on the drive axle. The steer axle probably would be smart as well but I had no issues. I did not nor would I do the tag tires. I did not do inner tires nor would you install it there I don't think as you have to put them over top of the tire. You must adhere to the speeds and remove them when you're clear of the snow/ice. I destroyed mine probably by going too fast and not pulling over when clear of the snow. Their customer service was outstanding and they sent me a courtesy replacement. They do stow compact prior to use, getting them compact again after use would be interesting.
I do recommend if you find yourself in need. Again, I came up to a location where all the trucks were pulled over, I had no option to turn around, etc.
