Chuggs
- Nov 3, 2019
- Ventana 4037
- 40’
- Jeep JKU
That is just weird...
I guess the Precision Circuits thingy must get something from the Block Heater relay, built into the load center??
Oh well...
incidentally, we use our block heater all the time in Florida... well, kinda. See I added an outlet in the bedroom below the full length mirror for an oscillating tower fan. We like air circulation, and hated running the power cord up behind the tv. My outlet is powered by a plug,,,which we could connect to a 12Ga extension cord to work directly from the pedastle if we needed to run a space heater...but normally I plug into an outlet I added to the block heater branch. Weatherproof outdoor box located in the DEF compartment. I’m glad you raised the subject...b/c I was thinking of adding a switch to allow me to select inverter power for that outlet...but that would definitely be bad if the management/distribution circuit sees that. It would probably confuse the heck out of the system.
For heating the engine on the rate occasion...I had added the switch and pump to the Oasis... Works great.
Oh well...
