NWIP
- Nov 4, 2019
- No Where In Particular
- Dutch Star 4369
- 43’ 9”
- Spartan K2
- Cummins ISL9
- 2023 GMC Sierra
- Yes
Excellent info, thank you. Just viewed it.
It is probably not a bad as you think. I just got off the phone with Randy at ITR, and he trouble shot my issue in a matter of minutes. My problem is a thermostat that acts as a timer between the time you ask for heat and the time that it kicks on the heat, keeping you from dumping cold air into the coach. Give me a minute to write these trouble shooting instructions down and I'll forward them to you. It will only take you a few minutes to find out if your problem is the same as mine.Sadly, I am still fighting hot water issues and my passion and love fest with OASIS continues. No faults this morning and no hot water. It's been intermittent at times as reported before and I thought it was a fuse not seated well, nope. I turned off the diesel burner and electric elements as I was using the furnace for the night (not doing so great) and cycled the two breakers in the half bath. I turned on only the diesel burner and it came on, it would not come on previously but the green light was on. I have hot water.
I typically do the service kit annually but decided to wait until it was "needed." I think I may go back to what I was doing and do that annual service kit annually! So I'm going to do that but I think this issue may be external to that kit and I'll be putting in a call to ITR, placed on hold while Jim has a half day chat with them, and figure out what part(s) I need to throw at mine. Guessing some thermostat or something as it's 7 years old now and something else is likely failing.
I'm going to take Jim's dollar that's on my desk and apply it towards my parts. Sorry Jim!
So if anyone has any suggestions as to what part may be failing feel free to play my OASIS lottery too Time to re-read all those documents we've been throwing at Jim. I still want to see a picture of him wedged in the basement like me getting stuck in there!
Thanks. Is there a part I need to order? I was thinking of getting that thermostat, the electrical diagram link above shows it zip tied on and seems like an easy swap (famous last words).It is probably not a bad as you think. I just got off the phone with Randy at ITR, and he trouble shot my issue in a matter of minutes. My problem is a thermostat that acts as a timer between the time you ask for heat and the time that it kicks on the heat, keeping you from dumping cold air into the coach. Give me a minute to write these trouble shooting instructions down and I'll forward them to you. It will only take you a few minutes to find out if your problem is the same as mine.
BTW, it's a pretty easy fix.
Here is what you do to find out if that is the problem.Thanks. Is there a part I need to order? I was thinking of getting that thermostat, the electrical diagram link above shows it zip tied on and seems like an easy swap (famous last words).
I don't know if the Solar Pumps are inferior or not, but based on the unbelievable support these guys provide, I'm willing to spend the extra money for the ITR pump. If for no other reason than to support those who support me.I just called ITR and my issue is a circulation pump issue, nothing else. If the unit is up to temp the burner won't run, it's either pumps not flowing properly or the check valve is stuck so I need to tap that with a wrench. He agreed I did not need to use my service kit if it's been running.
I'll post this separately but he said the US SOLAR PUMPS are NOT to be used. They are not rated for heat or flow rate. Good thing I just ordered two that will not be used and have two coming from ITR (250ea).
