rv4travlin
- Oct 12, 2020
- Henrico VA
- forest river
- sunseeker
- 29'9"
- Ford E450
- V10 Gas
- Bufo quercicus
If it was, it never said so on computer, ever no present codes, no stored codes.. nothing at all.. starts and runs great everytime , never got hot ..just a loss off power whenever I kick into passing gear.. engine was actually pinging real bad was scary was worried about permanent damageSounds like it in limp home mode
Not the sensor you were correctKeep looking! I think it's not that sensor! Why? Because throttle sensors typically have a dead spot, and when past that location resume proper operations!
Thanks I will check it out
Check the ping sensor, may be called knock sensor. Crank position sensor. And timing chain.If it was, it never said so on computer, ever no present codes, no stored codes.. nothing at all.. starts and runs great everytime , never got hot ..just a loss off power whenever I kick into passing gear.. engine was actually pinging real bad was scary was worried about permanent damage
Yes fuel pressure is good no leak downHave you put a Guage on fuel pressure?
Regulator, fuel pump???
How do I check ping sensor?Check the ping sensor, may be called knock sensor. Crank position sensor. And timing chain.
Thanks I looked through all of them ,but nothing pertained to my citation
Just to verify throttle sensor you can test it easy enough
I have a scanner that shows live data..but I’m in Bay Area California and the shops I would trust to actually find the problem won’t take motorhomes..there are shops who would offer to try to diagnose my problem, but I don’t fell like paying for nothing…what I need is a Ford mechanic with tools and experience..where I’m at I haven’t found one..I would absolutely pay for someone to diagnose my problem…I think your going to have to put a scanner on it and get some live data. The Autel MX808 MaxiCheck is a good mid priced scanner at about $380.00. It is not a $90.00 code reader but a true diagnostic scanner. Current shop rate in my neck of the woods is now $195-$220 so does not take long to justify the cost.
Finding good mechanics is getting harder and harder. Not a lot info on your issue. But no check engine light so probably no codes. Has it been sitting long enough to have bad gas? Sounds like you have spark and fuel could be a timing issue, like it is not advancing due to a cam sensor. Early V-10s had issues with blowing out spark plugs. Maybe one or more plugs is not seated causing low compression. Maybe not engine related, but transmission? Just throwing spit balls. Can you drive it with the scanner and watch the O2 sensors, fuel pressure, timing advance, TPS, and look for torque convertor fully locked up. Using the scanner you can shut off one coil or fuel injector at a time and see if you have a dead cylinder. Unplug the EGR valve see if any change.I have a scanner that shows live data..but I’m in Bay Area California and the shops I would trust to actually find the problem won’t take motorhomes..there are shops who would offer to try to diagnose my problem, but I don’t fell like paying for nothing…what I need is a Ford mechanic with tools and experience..where I’m at I haven’t found one..I would absolutely pay for someone to diagnose my problem…
Google it! All I know is it is a detune measure!How do I check ping sensor?
You can be the best wrench mechanic in the world! But in a world of electronics that hides much of the old way of diagnosis, you are held impotent. The diagnosis from a competent technician is worth every penny you will spend on them!!! And everyone deserves a wage!!!I have a scanner that shows live data..but I’m in Bay Area California and the shops I would trust to actually find the problem won’t take motorhomes..there are shops who would offer to try to diagnose my problem, but I don’t fell like paying for nothing…what I need is a Ford mechanic with tools and experience..where I’m at I haven’t found one..I would absolutely pay for someone to diagnose my problem…
I’ve replaced all the gas and filter fuel pressure is good and doesn’t leak down sparks plugs are new coils were just replaced I actually had new ones on my shelf lucky me! I drove with scanner hooked up along with fuel pressure gauge and everything checks out thought I was missing something so I had another reputable mechanic I know ride with me he says the same just one of those tough jobs but I’m sure it will be something stupid easyFinding good mechanics is getting harder and harder. Not a lot info on your issue. But no check engine light so probably no codes. Has it been sitting long enough to have bad gas? Sounds like you have spark and fuel could be a timing issue, like it is not advancing due to a cam sensor. Early V-10s had issues with blowing out spark plugs. Maybe one or more plugs is not seated causing low compression. Maybe not engine related, but transmission? Just throwing spit balls. Can you drive it with the scanner and watch the O2 sensors, fuel pressure, timing advance, TPS, and look for torque convertor fully locked up. Using the scanner you can shut off one coil or fuel injector at a time and see if you have a dead cylinder. Unplug the EGR valve see if any change.
No code! No miss!Finding good mechanics is getting harder and harder. Not a lot info on your issue. But no check engine light so probably no codes. Has it been sitting long enough to have bad gas? Sounds like you have spark and fuel could be a timing issue, like it is not advancing due to a cam sensor. Early V-10s had issues with blowing out spark plugs. Maybe one or more plugs is not seated causing low compression. Maybe not engine related, but transmission? Just throwing spit balls. Can you drive it with the scanner and watch the O2 sensors, fuel pressure, timing advance, TPS, and look for torque convertor fully locked up. Using the scanner you can shut off one coil or fuel injector at a time and see if you have a dead cylinder. Unplug the EGR valve see if any change.
